So I’m trying to diagnose dead displays on a solar ride.
So far readings are:
Lugs: AC unless noted DC
7- 14v / 14v
6- 11.58v / 11.5v
4- 11.60v / 11.5v
3- 14v / 14v
9- 35v / 69v (do 8 and 9 combine to make the 69v?)
8- 35v / 69v
12- 2.65v / 5v
11- 8.1v DC / 8v DC
10- 2.665v / 5v
15- 1.537v /3v
14- 4.147v DC / 4v DC
13- 1.54v / 3v
Oddly to me the readings that are approximately half what they should be start where they should be for a split second then settle to half value.
To get these reading I’m putting black wire on lug 5 and red on xformer outputs. Is this the correct way?
Another odd to me thing…. TheAC line in filter outputs: one has two white with grn/blk stripes and reads 67.5v. The other with white with red/blk stripes reads 50v. The maintenance outlet reads 117v.
Does this sound like a harness issue and not a transformer issue?
Thanks. I’m no electrician so please be easy on me!
****update.
Checking outputs of the A2-P3 pin 1 is 60v pin 3 is 40 volts and pins 7 and 8 are reading 1.4vdc and 1.5vdc respectively.
