Quoted from Piparoo:Yeah, I just checked Marco and they have a full Mylar for Space Station but not Space Shuttle. Weird. So, if I put a Mylar piece above the rollovers what is the right shape for the piece of Mylar? Should I get one of those half-circles and put the flat side up closest to the metal?
Cut your own. Take a piece of tracing paper and lay it there and trace out a shape that covers the damage. Turn it over on the back side of the mylar and trace around it with a pen. Cut it out. Without touching the sticky side, peel back a 1/4 inch of the backing. An exacto works well. With the backing folded under, holding the exposed sticky off the field, position the mylar into place. Once in place, tap down on the exposed sticky to nail it down. Then fold it over, grab the backing and peel it away while gently pressing it into place. Rub out the tiny air pockets with the back of your fingernail.
