I am getting ready to test the first of two optical solutions. Since all of my other machines (WoZ excluded) have undercab flashers bars I built, I wanted one for KISS as well. So far, I have added two optical mods to this game. The first is LEDS in the demon mouth and under the plastic behind it (facing down). Using a simple photoresistor, I was able to tie it to the LOCK insert. I did the same thing with the ramp that goes behind the back panel. I used purple strip leds and put a photoresistor under the mode insert for the ramp. The ramp glows purple, and at different intensities based on the mode. Its is a subtle but nice effect. For the ramp light, I simplied the design and used a static value resistor. The mod is tiny( built into a cable), modular and plug-n-play. I have since built several of these for applications that are best suited for this kind of mod.
For the next stage, I am using a IC on a board that will drive 8-channels. I am testing the board in KISS this week so the plan is to use it to (optically) tie into the flashers and drive my undercab flasher bars. Since it will be completely generic, I can not only use it for SPIKE pins, but pretty much any other pin as well.
**I should play my pins more, but I have fun modding them too.
