Directions for cable adaptor harness: Abbreviated
WARNING: do not connect or disconnect cables to a pinball machine while it is on. You could shock yourself or do damage to the boards.
Steps:
1. Locate 6 pin power IDC connector (J11) on cpu board. This is located in the upper left corner of the board
2. unplug and note pin labels:
1: +5V
2: GND
3: -12V
4: AGND
5: AGND (header pin clipped)
6: +12V
NOTE: The harness will add a bridge that has wires for pins 1 (+5V), 2 (GND), and 6 (+12V). For the back box LEDs, we will be using only the GND and +12V. The +5V may be used for other mods (e.g., addressable LEDs)
3. Cut 5 short wires that will be used to connect IDC header to connector
4. Cut three long wires that will be used to bridge pins 1, 2, and 6 to back board or other mods
5. Hold 6-pin IDC connector with helping hands
6. Solder 5 short wires to header pins 1, 2, 3, 4, 6
7. solder 3 long wires to header pins 1, 2, 6
8. cut and place heat shrink over the wires and exposed pins
9. heat and shrink with heat gun
10. pin small wires with crimp contacts if using an IDC connector that requires them
11. push pins/push wires into IDC connector
12. double check that you pinned the harness correctly
13. clip pin 5 from header so it can be plugged into connector J11
If you have an RGB color changing module, times to wire it to the harness.
1. Pop it open
2. Solder the ground and 12V wires from the harness as shown in the picture.
3. Test. If it doesn't work, try switching the wires.
4. Close it
5. Attached it to the head with double sided tape.
If you don't have an RGB color changing module, you can wire directly to the back box LED lead. For white, bridge the RGB inputs together and connect to the negative wire. 12V+ to the 12V on the LED strips.
Completed harness
Directions backboard: Abbreviated
1. Cut foam core poster board to size (25"x18")
2. Measure and poke holes for mounting posts
3. Remove yellow tabs holding in florescent tubes
4. Remove florescent tube
5. Remove florescent tube holders
6. Tuck florescent tube holders behind florescent tube mounting plates
7. Remove florescent tube starter
8. Screw in 6x32 3" rods into florescent tube mounting plate
WARNING: Make sure it is in far enough so that the ends don't hit the translite!!!
9. Put small lock washer on rods
10. Tighten 6x32 nut against lock washer to hold rod in place on mounting plate
11. Put two 6x32 nuts onto each rod, about halfway down. These will be the backstop for the poster board
12. Tighten the two nuts against one another to lock them in place
13. Test fit the poster board in the back box (adjust as necessary -- you can bend the rods widen holes, start over)
14. Cut light strips (lengths of twelve sets of three LEDS for the one shown in this example)
15. Measure poster board to space LED strips. (Number of strips + 1)/18". For the 6 strips shown here, that is ~2-9/16" from end to first strip and between each strip
16. Cut slots in edge of poster board to run wires for the LED strips
17. Remove backing and apply LED strips.
NOTE: Since you will be tapping into the 12V power on the cpu board (right board on SAM systems), it will be easiest to leave a connector free on the upper right side of the poster board (with the LEDs facing you)
18. Connect wiring in serial.
NOTE: doing steps alternating steps 17 and 18 help make sure that you orient the LED strip (12V top or 12V bottom) correctly. Exactly how to connect the wires depends if you have quick connects or solder. This example uses both.
NOTE: if soldering, make sure to tin (put solder) on the LED strip pads and the wire before soldering together.
NOTE: if using quick connects, I noticed a fraction were shorted or made bad connections
NOTE: Test the lights and the color channels as you go, this makes it easier to find and correct problems
19. Pull wires through slots
20. Tape wires to back of poster board
21. Glue flange washers to rod holes on poster board (protects the holes)
22. Connect to power, mount, enjoy!
Completed backbox:
Post edited by lyonsden: Added abbreviated directions for backbox
