Suggestions please. Can I use a silicone lubricant or do I need to purchase a new assembly/spring?
Usually you just clean the assembly and put a new sleeve in it.. I use mothers mag cleaner on each one I do, and put a new sleeve in the assembly, has not failed me yet!
Please see this thread:
http://pinside.com/pinball/forum/topic/does-anyone-out-there-wax-their-balls
to see where THIS thread is going.
You can clean it with Novus 2 and 1, but make sure that you don't leave any residue behind. No need to use lubricant if it's kept clean.
Quoted from balboarules:Usually you just clean the assembly and put a new sleeve in it.. I use mothers mag cleaner on each one I do, and put a new sleeve in the assembly, has not failed me yet!
Yep, just take it apart. Clean it and a new sleeve and you're good to go.
How to lubricate a sticky shooter rod.
80's PinPorn for the evening.
Does anyone out there wax their balls?
I had to do a double take when I saw the front page to make sure I was on Pinside and not some X-rated board ...
Quoted from jfh:How to lubricate a sticky shooter rod.
Next new topic will probably involve gobble holes.
Mine has lithum grease that caused it to bind. Remove the gunk and polish (if u can). If you need to lubricate, the best is to use a little graphite.
Ditto. If it's thoroughly cleaned, it shouldn't stick.
Ron...
Quoted from vid1900:No lubrication is needed at all, ever.
One of the first things I do when I buy a machine is clean the shooter assembly. Besides the sleeve, I usually end up replacing the outer barrel spring as well, since they are often all rusted or tarnished.
What machine is it on?
Data East/Sega/Stern uses metal-to-metal contact between the shooter rod and a bronze bushing. You need to oil that with a drop or two of any good oil.
Williams uses a nylon sleeve (smaller diameter than a coil sleeve) and should never be oiled. All that is needed is a new sleeve and to polish the shooter rod with either chrome polish or Brasso.
Like others have said, no lubrication is needed...EVER. The reason why it is sticky is someone had lubricated it in the past and now it's all gummed up. Take it apart, clean the sleeve and shooter rod. I use a Scotchbrite pad to polish the shooter rod. Put it all back together and it will be as smooth as silk.
Quoted from KenLayton:Data East/Sega/Stern uses metal-to-metal contact between the shooter rod and a bronze bushing. You need to oil that with a drop or two of any good oil.
Quoted from schudel5:Like others have said, no lubrication is needed...EVER.
These are conflicting statements. I know that you shouldn't ever lubricate the ones with the nylon sleeves, but is it correct that you should lightly oil the Stern ones?
Quoted from gweempose:These are conflicting statements. I know that you shouldn't ever lubricate the ones with the nylon sleeves, but is it correct that you should lightly oil the Stern ones?
Not sure what others do, but I never have. As the brass/bronze is a self lubricating material used in place of bearings on some cheaper electric motors.
Now, some older games did not use brass or a sleeve. In in these cases I have found that you can drill out the shooter housing slightly and add a nylon sleeve.
Quoted from gweempose:I know that you shouldn't ever lubricate the ones with the nylon sleeves, but is it correct that you should lightly oil the Stern ones?
I always oil the new Stern ones because of metal-to-metal contact.
Quoted from KenLayton:I always oil the new Stern ones because of metal-to-metal contact.
Looking in the Stern manual for Spiderman in Section 4, Chapter 2, Page 64, in the exploded view of the shooter assembly, there are two 3/8" bushings #280-5010-00 which are manufactured by Oilite.
Here is the Wiki on Oilite:
http://en.wikipedia.org/wiki/Oilite
No need for adding additional lubricant...
This page was printed from https://pinside.com/pinball/forum/topic/how-to-lubricate-a-sticky-shooter-rod and we tried optimising it for printing. Some page elements may have been deliberately hidden.
