How do you all practice to improve your pinball game? I play enough that I should be better than I am, and I don't seem to be improving in some critical areas...
I currently own two tables (No Fear, Twilight zone) - and while i've had some good games on both, I still suffer far too many 30 second games on twilight zone (you know, 30-100m points, balls draining with virtually no play time, etc). I think my average is in the 150m range on TZ (factory settings, outlanes moved to the least-open position), and the 700-900m range on No Fear (Factory settings, outlanes in middle position).
I can do flipper passes pretty well, and I'm okay with aiming. That I know how to work on, at least, and am improving with.
The big areas that I’m having trouble with are:
*Things that could be slap saved. I just don't know how to pull off a slap save. I've seen people do it tons of times, and the main friend who i play with is a master of it. But i just can't seem to do it, on two fronts:
I can't seem to get enough force to move the machine side-to-side with a slapping motion, and certainly not quickly. When you do a slap save, how far from the buttons do you move your hands before bringing them in? Maybe I’m not moving them far enough to get enough momentum to have any effect? Am I just too weak?
Secondly, the timing - I’m not confident that I’m getting the timing right when I try it either, because the motion of slapping is so different than just hitting the button.
I don't even know how to practice slap saves. I'd like to be able to practice the technique, so i know I have that down, then try to learn to apply it, but I can't think of a way to separate the "doing a slap save" from "recognizing a need to do a slap save and attempting it in time"
*Bungled flipper catches, where I think I’ve caught the ball, but it's got just a bit too much momentum and rolls off the tip of the flipper. I just can't seem to make any progress improving on this. How do you pull out, if you've started a flipper catch, but then realize the ball is moving too fast to stay on the flipper?
*Saving balls from the outlanes. My friend is real good at nudging balls out of the outlanes. I do not seem to be able to do this. I don't know which way I’m supposed to nudge the machine at what point, and have never been able to save a ball from the outlanes on a machine with a tilt (my successes were all with very vigorous physical assaults, using both hands to get more force behind it).
Thanks...
