FYI:
If you’re a DP owner/player, you may have noticed on some machines that the exit from the right orbit will send the ball into the left sling, rather than to left flipper, spoiling one of the funnest combo’s in pinball (“Ninjapocalypse!”). There is no way to adjust this out. It’s just a random misalignment that some machines suffer from. If you would like to know my personal fix, involving the fabrication of a “wedge,” read on.
Ballguide Wedge Instructions:
1. Remove two nuts that secure the left ramp's wireform and swing it out of the way. It's not necessary to remove it. It will pivot where it meets the stainless ramp. Next remove the large plastic assembly that includes Dazzler, then remove the rubber ring associated with the drops bank, as well as the upper post it wraps around, and the post that secures the midpoint of the wireform.
