Quoted from fossmin:Anyone have a trick for getting this nut on the power switch under the cabinet. Can't seem to get it starting in the limited space.
pretty sure i just carefully use needlenose pliers.
i hope someone's got a better idea.
If the switch keeps pushing into the cab when you try to add the nut, have someone hold it or tape/weigh it down.
If you don't have enough room for your fingers to get the nut started, small channel lock pliers.
Place nut on threads.
Turn nut CCW as if loosening it.
When the nut sort of "snaps" onto the threads, begin turning CW.
Boom!
Chris Hibler - CARGPB #31
http://www.ChrisHiblerPinball.com/Contact
https://www.youtube.com/c/ChrisHiblerPinball
Check the threads on the switch. Take switch out and thread the nut on outside the pinball machine see if it goes on smoothly.
Does the switch mount through a plate? If so remove the plate and mount the switch from inside the cabinet.
Quoted from twhtalm:Does the switch mount through a plate? If so remove the plate and mount the switch from inside the cabinet.
This was the winner. Thanks for eveyone's help.
This page was printed from https://pinside.com/pinball/forum/topic/how-to-get-this-nut-on and we tried optimising it for printing. Some page elements may have been deliberately hidden.
