Quoted from ThePinScientist:Simple way to fix cupping on inserts. Super easy and they do their job.
TheEMScoreKeeper.com $5 for a full set of Invisible Mylar Insert Stickers. Free shipping.
You are simply trying to use mylar to accomplish filling or replacing. I do understand what you are selling and for many people, is a reasonable solution.
It depends on your perspective of what pinball is and what you can live with. The playfield is manufactured to be a flat surface and as we all know and cupped inserts ruin the playing experience.
If an insert is severely cupped, a single layer of mylar will droop over time. Stacking the mylar to get the result flatter is needed using varying sizes as stated in your video.
Not all inserts are created equal. Maybe someone else can shed light on why but from my experience Gottlieb cupping is far less pronounced than Williams or Bally's of the same era.
You see lots of forum posts about a Gottlieb insert that simply falls out or has suffered severe shrinkage. The inserts tend to be pretty easy to pop out. I'm not sure if the plastic they used was from a different supplier than William's but I doubt it.
I'm in the process of restoring an Aztec and have replaced the inserts due to severe cupping commonly seen on William's. I would assume that William's playfield insert hole diameter was slightly smaller than Gottlieb's. Getting inserts out when this tight can risk cracking/delaminating the plywood at the insert location.
I hate dealing with inserts as much as the next guy. Even tried using a heat gun to flatten them out. Now this does work, but to a limited degree. Can't get it perfect but you can reduce deep cupping this way. In fact, I might suggest doing this first then the mylar for a better result on really bad inserts if you can't replace them.
What I'd love to see is an easy yet durable long term solution that easy enough for anyone to do. The closest thing I've seen is the windshield epoxy cured with UV. Haven't tried this yet but looks interesting.
But please don't be dismissive of reality and state your product "fixes" cupped inserts. It alleviates the issue but doesn't resolve it.
