(Topic ID: 108436)
How to fix Flintstones ball falling off arch
By Blackbeard
7 years ago
  • 15 posts
  • 10 Pinsiders participating
  • Latest reply 10 months ago by Flippermatt
#1 7 years ago
So many flintstones have the issue that when the ball runs behind the flippers, the ball can sometimes fall off the plastic archway and drain. It'll spot you a free ball, but it's still a drain.
This situation seems to occur after one shops the game. Hmm. Strange. This is the way mine started acting up as well. After I shopped it.
After asking around (props to members Cody_Chunn and t2) and adjusting it myself, it comes down to LOOSENING two screws only: one screw on each inlane, closest to the flippers. Loosening these two screw just a bit will raise up the plastic archway just a bit, so that the ball doesn't roll off. They don't have to be super loose, just not tight.
You see, after a shop, we all tighten screws down good. Here, a simple one minute fix is all it took.
Documenting this for Flintstones owners in the future. Pretty damn fun pin.
#2 7 years ago
Blackbeard,
Thanks for the tip. I have this problem with my 'stones. Anyway, would you be willing to post a pic of the screws that you're referring to? I think I know which ones, but just wanted to be sure, and maybe make it easier for anyone else having this issue. Great tip! Thanks.
#3 7 years ago
Blackbeard glad to hear that loosening the screws worked. I about fell over when a half turn of the right screw solved 3 months of frustration. Very fun pin!!!
#4 7 years ago
These are the two:image.jpg
#5 7 years ago
This should help, assuming your pin is leveled and pitched normally.
#6 7 years ago
Thanks for the post. Have not shopped mine out yet but it's in the plans.
#7 7 years ago
Simple easy shop.
#8 7 years ago
I had the same problem with my Flintstones. I placed two small plastic washers underneath the two screws. Problem solved.
#9 7 years ago
I made a little plastic mod works great
#10 7 years ago
pic # 2
#11 7 years ago
Quoted from Turboderf:
flintstone apron 1.png 501 KB
Unnecessary, but hey if it works...
#12 7 years ago
Awesome. Thanks for the pic. I'll make that adjustment this weekend.
#13 7 years ago
Just shopped mine today and had a few roll off. Great tip, thank you!
5 years later
#14 1 year ago
5 years after this post... Can confirm the described fix still works. Just now fixed my dad's recently shopped Flintstones - nice that it was so easy!
5 months later
#15 10 months ago
Quoted from daveyvandy:
Just shopped mine. Are there supposed to be washers on the underside ? Mine didn't have any... If, yes how thick are they ?
Mtt
