Wires from coin door insert into half of a white plastic connector which joins a mated opposite. The halves are held together by springy fingers with little flat-ended ramps to keep the connectors from separating. I can't figure out how to get the springy ramps depressed so that I can take the two sides of the connector apart. Any suggestions?
I'm trying to get my "QUARTER" lights to light on the coin door but they are getting no voltage. I suspect a bad connection inside the first connector box.
