(Topic ID: 256468)
How to dim GI bulbs?
By P2K
  • 11 posts
  • 9 Pinsiders participating
  • Latest reply 4 years ago by mbwalker
    #1 4 years ago
    I have a re-theme project on a Gottlieb Buck Rogers SS machine where I need to have dimmer GI lights on the playfield.
    Probably around 25-50% dimmer, but doesn't need to be variable.
    I will just find one light level I like and keep it there.
    Is it as simple as putting a resister(s) at the beginning of the GI strings?
    Other ideas?
    I've already painted the bulbs red for a dimmer effect but still too bright.
    Thanks.
    Alan
    #2 4 years ago
    Quoted from P2K:
    They would get very hot but yes this is an option. You can use a bridge rectifier to knock drop @ .6 or 1.2 volts depending on how you wire it. You can put 2 or more in line to drop another 1.2 volts for a total of 2.4 volts.
    ebay.com link: 2Pcs 1000V 50A Metal Case Single Phase Diode Bridge Rectifier KBPC5010 USA
    #3 4 years ago
    It could be as simple as using 47 bulbs instead of 44s.
    #4 4 years ago
    Bulb condoms dim them down a good bit if you dont mind colored.
    CAA9ED42-61B7-4FF1-8FFC-3FE48C35E27D (resized).jpegCAA9ED42-61B7-4FF1-8FFC-3FE48C35E27D (resized).jpeg
    #5 4 years ago
    Quoted from o-din:
    Or other bulb...a #267 bulb is spec’ed to be even dimmer than a #47.
    #6 4 years ago
    Quoted from yendor0:
    Thanks! You saved me the journey.
    #7 4 years ago
    I don't know if they make a GI OCD that is compatible with that particular game, but that might be an option?
    #8 4 years ago
    Dial it down with a potentiometer.
    #9 4 years ago
    Quoted from Lamprey:
    It is not compatible. The best option, in my opinion is choosing dimmer bulbs as mentioned above. Are we talking incandescent or LED?
    #10 4 years ago
    Quoted from P2K:
    You could try simply taking out some bulbs.
    #11 4 years ago
    Quoted from herg:
    I was wondering the same thing. If LED, could be as easy as going from 2 LED bulbs to 1 LED.
    This page was printed from https://pinside.com/pinball/forum/topic/how-to-dim-gi-bulbs and we tried optimising it for printing. Some page elements may have been deliberately hidden.
