I have recently got a Roadshow going that had been sitting for a number of years with a range of faults with an operator.
Played fine for 10 games once i got it going, then had a shutdown mid game and got a ground short error.
Replaced U20 and U23, problem fixed....for another 15 games, then same thing has just happened.
So I assume there is a loose/stripped/kinked wire somewhere (presumably from a coil or lamp) that is shorting through a switch or switch wire and taking out the U20 and U23 chips- is this correct?
Does the fact that it takes out 3 rows (5 ,7 andmean anything - ie: should i be looking at switches and wiring associated with those 3 rows, or could it be any switch.
I have had a reasonable look, and most switches look OK, and coils that are mounted near switches don't have any obvious loose wires near a switch wire.
Anything else i can look for, or quick tests that could narrow the search down (i am thinking not, since the problems appears very intermittent)?
Once it happened when i had 3 balls locked and preparing for multiball, the next time it was going for the blast zone - so different coils/switches at work both times.
