Thanks to the help of some friends, my basement gameroom is once again moving along...
Having said that, one of the next things that I REALLY need to figure out is soundproofing. A little background...
Our house that we moved to last year is from 1888. It is actually a duplex, and we are living on the second and third floors of it, and the gameroom is in the basement. We have tenants living on the first floor. As of right now, the soundproofing is non-existent. The underside of the floor is straight ductwork and rafters in the majority of the basement. It's a tall ceiling.
While I would like the ability to get to the rafters relatively easily in case ductwork or anything ever needs to be done, I do not plan on running anything else through this area like speaker wires or anything like that.
With all that said, from what I have been able to see, mass loaded vinyl seems the thing to do. What I don't know is if I put that up, would I need to add anything over it? I was hoping to make the ceiling black anyway, so this seems like it might work out just fine. From what I can tell, this would dramatically reduce the sound of the games for the tenants - is this correct? I don't want to spend a ton of money and time on the project if it wouldn't help that much more than just putting up some plywood or something.
Any help would be greatly appreciated. The online information that I search for doesn't seem to answer leaving the MLV exposed, and is mostly described as "in wall" applications.
