Bulb pliers is the best way, I finally bought a set after a few of these.
Stick a shooter tip on it and see if you can get a grip on it.
Lay a towel under to catch the pieces if you bust it horsing it around.
Just replace the spot assembly. The reflector is badly corroded and the socket is probably trash.
They are $2.95 at PBL with leads.
http://www.pinballlife.com/index.php?p=product&id=1542
or $2.45 without leads. (reflector and socket)
My scared stiff goody bag had a small piece of clear rubber hose like you get at a hardware store for sliding over the spotlight bulbs to change them. Probably 10cents worth and its handy to have around. Just take a bulb to the hardware store.
Quoted from roc-noc:Just replace the spot assembly. The reflector is badly corroded and the socket is probably trash.
http://www.pinballlife.com/index.php?p=product&id=295
This is the solution you were actually looking for.
Quoted from canea:I had this exact problem a couple of weeks ago. I ended up using a small pair of rubber-tipped craft clamps. They worked perfectly.
oh, i like that idea!
Pretty sure the reflector snaps on. Just unsnap the chrome reflector and the bulb will come out with it.
Quoted from Mrjamma:Pretty sure the reflector snaps on. Just unsnap the chrome reflector and the bulb will come out with it.
On Sterns, not B/W the socket and hood are one piece.
If the bulb melts to it and you do get it out you have to scrape the inside of the hood to get the new one in there.
Best to just replace it.
DITTO x 2
This page was printed from https://pinside.com/pinball/forum/topic/how-to-best-remove-this-bulb and we tried optimising it for printing. Some page elements may have been deliberately hidden.
