(Topic ID: 256787)
How to adjust switch Ghostbusters
By marspinball
    #1 4 years ago
    The E rollover switch which is part at the top three PKE rollovers is not registering. Went to adjust it under the playfield and it's attached to a plastic bracket that is screwed into the playfield.
    There is nothing to adjust. I tried bending the wire so it would be a bit higher but did not help. Switch seems to work manually.
    Can it be adjusted or do I just replace. Where is the best place to order if I need a new one?
    #2 4 years ago
    Can you post a picture please ?
    #3 4 years ago
    Quoted from marspinball:
    It can be bent into the correct position.
    Maybe take it off and make sure the switch is working first before you buy a new one.
    This page was printed from https://pinside.com/pinball/forum/topic/how-to-adjust-switch-ghostbusters- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
