(Topic ID: 180771)
How to adjust a ball shooter
By wylcot
2 years ago
  • 12 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by QuyN
    ec90782245ef667a7d90ffe18735806adf64925cf735e11fa803eacd104c5556 (resized).jpg
    #1 2 years ago
    My question probably seems silly, but i just can't understand how to adjust the ball shooter, or launcher (?).
    I have a Pinbot on which, over time, I just couldn't reach the skill shot.
    Same problem on my Taxi
    And kind of the same on my The Machine: Bride of Pinbot
    I changed the springs for new ones. Also changed the rubber.
    Nothing changed.
    Am I missing something?!
    #2 2 years ago
    Even if you think it's a silly question because you don't know, that's how we all learn.
    Is the rubber tip/plunger centered in the middle of ball at rest when it kicks into lane, and is it clear of the shooter housing?
    #3 2 years ago
    Thank Cash!
    Well, i know that it is not exactly, on Taxi...
    But then, do i have to adjust the rod??...
    #4 2 years ago
    Inside the cabinet should be 3 screws on shooter housing. Loosen and adjust to a correct alignment position of the shooter rod to ball position. Center/left/right etc. You can just snug the screws up and test before fully tightening. Give that a shot first. From there another step and more if not corrected! : )
    #5 2 years ago
    Lube the shaft with super lube. Maybe the shaft is dragging on one side of the nylon bushing.
    #6 2 years ago
    Use a red spring.. and if you need to you can shim with a,washer .... my pinbot was the same way .
    #7 2 years ago
    wylcot just checking back to see if you are 'one' w/your shooter alignment yet. : )
    I was just on RGP reminiscing about my ol' TEAM-EM days when pinball was fun : ) and took a look-see into your Pinbot shooter problem. Seems to be a common problem! For your reading pleasure(and hopeful fix if shooter housing adjustment didn't get you right) take a LQQKY here:
    https://groups.google.com/forum/m/#!search/Pinbott$20shooter$20issue/rec.games.pinball/gk5Wau6ps_I
    #8 2 years ago
    ^^^Crud, link NG!^^^ If you go to,RGP(if not familiar post back) go to search and type in: Pinbot shooter adjustment and then look at the one titled: Williams Pinbot - shooter housing adjustment.
    #9 2 years ago
    And thennnnnnnnn so I don't babble any more tonight, : ) right here on Pinside:
    https://pinside.com/pinball/forum/topic/hitting-the-pinbot-vortex-well-adjust-the-shooter-screws#post-1992745
    #10 2 years ago
    Well, I hadn't seen taht thread!
    It's a relief to see that I'm not the only one to struggle with that issue!
    Well, I changed the spring for a red one, and lubed the rod... so I guess I'll try these 3 screws...
    Thank you guys! I'll let you know!
    #11 2 years ago
    Quoted from wylcot:
    #12 2 years ago
    From what I've heard, all Taxi's need fine tuning to get a proper skill shot lined up. There are threads about it. I have one, and I had to loosen the screws holding in the plunger and adjust to so that I can get all the way past 100K to 5K. It just takes a lot of trial and error. I'm going to replace the spring and the rod sleeve too, since it's makes that creaky spring compressing sound, so I hope that smooths it out. Also, if you don't have a new ball, or your ramp is dirty, it'll take a lot away from the momentum and you'll lose that good spin needed for the spin out.
    $ 0.00
    Operation Pinball
    $ 44.00
    $ 76.95
    $ 44.00
    $ 119.95
    Hookedonpinball.com
    $ 149.00
    Sparky Pinball
    $ 19.95
    $ 119.99
    $ 14.95
    $ 299.00
    $ 119.99
    $ 94.95
    $ 126.95
    $ 369.00
    $ 5,599.00
    Classic Game Rooms
    $ 19.00
    Sparky Pinball
    $ 5.00
    Doc's Pinball Shop
    $ 42.00
    Medisinyl Mods
