(Topic ID: 173303)
How to add custom music to older pin?
By Star_Gazer
  • 16 posts
  • 7 Pinsiders participating
  • Latest reply 4 years ago by PinballAir
  • Topic is favorited by 7 Pinsiders
#1 4 years ago
Hey pinsiders!
Altough my Stern Lightning has got some cool soundseffects,the "hearth beat" sound just doesn't do justice to this machine. So i want to ad custom sounds-tracks (normal play & multiball and maybe some variations)...the budget way. (less then 50$)
Any ideas?
#2 4 years ago
Used karoke machine off of craigslist.
#3 4 years ago
What about an old 8-Track Player, instead of drop targets, the ball hits a different number playing a different song.
What's that cost, like $8 at GoodWill?
#5 4 years ago
Quoted from LTG:
Hmm i am actually good in beatboxing...
#6 4 years ago
That is the way to go.
I put it into a rifle game so each of the targets was a different sound.
Up to 16 different tracks.
#7 4 years ago
swinks thanks for the tip, the custom made ghostbusters games also uses that for sound & music the guy is explaining it really well on youtube.
#8 4 years ago
Quoted from Star_Gazer:
Thanks, I try.
One key advantage I heard about with the .wav trigger over the older .mp3 triggers I had used, is that the .wav trigger will play and overlap more than one sound at a time. Otherwise, they seem to work the same way.
#9 4 years ago
Quoted from Betelgeuse:
So you could have a soundtrack and effects at the same time, with a single board?
#10 4 years ago
I set up the rifle game to play the good ,the bad, the ugly theme when the coin drops and for a duration of 1.5 minutes while playing the game.
Then each target shot is an individual sound effect.
I have 14 different sound effects that can overlap each other.
When you get tired of one set of sounds just set up a new disc w/new sounds.
#11 4 years ago
yes the Wav board allows you to run say a full song say on ball launch and then other switches trigger other different sounds overlapping the original song being played.
1 month later
#12 4 years ago
Does anyone know if the WAV trigger can be directly connected to existing Pinball switches? I tested the voltage on mine and they are at about 1.7V
#13 4 years ago
Quoted from bimm25i:
Yes that would be interesting to know..
#14 4 years ago
Yes, exactly.
This does not work with the MP3 Trigger so I would assume it does not work with the WAV Trigger. I have heard of succesfully using opto isolators to safely 'split' the signal from the switch to both the machine and the trigger board, but the costs can add up.
3 weeks later
#15 4 years ago
It requires an isolated set of contacts that make momentarily.
I used the 50 volt signal that energized the targets in the gun game to energize 48v "ice cube " relays.
Relays like these can run $2 to $25 each and the base is another $5 each.
The WAV trigger has a ground strip ( buss) and 16 individual hot connections.
Making the a hot to the ground buss ( or any ground) will play that particular sound.
You cannot back feed it any voltage thru your switch source. So it needs a dedicated momentary switch.
On their website they have the programming manuals free.
They have other ways to trigger the sound but if you make contact too long it will play that sound effect stacked one on top of another.
I also had ghost triggers. I suspect it was the magnetic field from the coil closest to the board.
Earthen grounds and shielded wire did not cure this.
#16 4 years ago
Sound board with relays.
Top LH corner is the Wav Trigger board.
