The Raptor kicker solenoid on Jurassic Park isn't working. I just need to know how to get to the coil because I'm sure a wire has come loose. Can't seem to figure it out, looks like it might be built into the playfield.
It is on top of the playfield. You need to remove the plastic over it. Which means you need to remove a couple of things, including the plastic around the T-Rex. While your in their, may as well give that area a good cleaning.
Alright thanks. Thought I would have to remove a ramp or something more involved. It's getting a new coil sleeve too. That shot is meant to be wicked fast.
When I accessed it during shopping I had the ramp removed and I figured that it was probably a requirement however you might be able to wiggle it out if you can get to all the lock nuts.
If you're removing this plastic I'd recommend cleaning and waxing the captive ball trail too.
This page was printed from https://pinside.com/pinball/forum/topic/how-to-access-jp-raptor-kicker and we tried optimising it for printing. Some page elements may have been deliberately hidden.
