Quoted from BLACK_ROSE:Look at this Moron ,, If that was my JM , his AZZ would have been Stomped !!!!!
This guy has other issues beside not being good at pinball.
Quoted from The_Gorilla:I nudge nearly all the time...edit. now that I took your poll, my real answer isn't there. Lotta nudging, rarely tilt
Same here. More nudging doesn't mean more tilting
How about when you're playing on location and tilt your 3rd ball to end the game and realize if you just let it drain the bonus would have put you over the replay. Replay at 50M, my score after tilt 49,895,000. Arrgg.
I nudge as far as a machine will let me. You can set the tilt bob as sensitive as you want so a mouse fart causes a warning. If you dont like people nudging your machine and want them to gingerly caress your flippers or else cause a tilt then set it that way. I wouldn't like people beating on my lockbar or my glass though, thats a benefit reserved for me
Quoted from gweempose:NimblePin said:Bang Backs are also a BIG NO-NO! Especially at my house...
If I saw somebody do a Bang Back on one of my machines, I'd be inclined to perform a Bang Back on their skull!
Just Bitchin I guess, but glad those weren't my machines there. I would more than likely said something.. Maybe I'm just a dick IDK?
Bill in Indiana
If the operator has not idea about setting up the tilt or they just dont care, then I will take advantage of that for sure.
Nudging is an inherent part of playing pinball, otherwise there wouldn't be a tilt plumb!
I nudge, slap, slide, jiggle the machine all of the time. If a machine has the tilt set liberally, then it is an open invitation to manipulate the machine to your advantage.
If you do not want people to perform death saves/bang backs, or overly nudge your machines, then keep your tilts TIGHT.
Like I said, I am physical with my games. They are meant to be played after all.
That being said, I do keep the tilts tight on my games. People may(and do) complain to me about it, but when I am in a competition where the tilts are tight and it counts, I am less likely to tilt.
LEE
I pretty much never nudge, I'm always afraid that it'll contribute to something breaking under there.
Quoted from Kingoftron:I pretty much never nudge, I'm always afraid that it'll contribute to something breaking under there.
That's Kinda the way I feel, Hell i just Moved BSD from 1 end to the other in the GRG and I had a Credit dot ( a Year or so ago ) and I Sure as Hell Don't want to Bump/Nudge TZ !!
Quoted from BLACK_ROSE:I Sure as Hell Don't want to Bump/Nudge TZ !!
How about a gentle caress then B_R?
Like the others echoed, nudging is an integral part of pinball, just like flipper skills. It doesn't take much to coax a ball back from the edge of the dreaded abyss. Practice makes perfect... Or, you can just pick up an IM and it will be a mandatory "Oh $#!t" save every 5 seconds!
My pins I nudge alot but never tilt or get warnings.
I agree with older pins nudging is a part of making good scores.
Other peoples pins on location alot lighter nudging.
Other peoples pins at home location usually will not nudge even if told it is ok.
Watch Gomez Nudging the BIBLE in this video,, the ball is in the Pop-bumper area , why Nudge or Bump when it's in that location ? I was @ Shanetastic's 2-nite , Played his RBION ,, All j=his Pin's ,, talk about Nudging ,, He would almost bring his IM off the ground to the Left or right, That Left Ramp if it don't completely make it up , It Will head SDTM..
If you wear a motorcycle helmet with horns coming out of the sides of it all viking style, you should nudge... Just sayin. I guess by the same logic, if you wear a motorcycle helmet with horns coming out of the sides of it all viking style, people should probably listen if you tell them not to nudge your table...
I usually rely on my flipper skills to get outta trouble, but will shake it on the outlanes.The occasssional push to get some more pop bumper action.Over all I think I "hudge" less than others.Scott
i nudge hard! what i love is to drag the machine to the side and sometimes i get away with it muhahahahahahah
B_R, You have that Ac/Dc on the way, you will have to nudge or slap to get that ball from coming SDTM sometimes. Its just a fact of life to avoid those short ball times. But you know when it's excessive with the tilt warnings, even without them you know how much is too much.
A recent classics tournament taught me how to nudge, it doesn't have to be too hard, just a gentle jitter to get away from those outlanes.
Quoted from cevans82:if its someone elses i try to keep it to a minimum but mine i nudge quite a bit.
Well said, that's the right thing to do, also route machines are not someone's collection.
I nudge enough to be effective, only when absolutely necessary. However it really pisses me off when it's going straight down the center or is already down the out lane and someone gives it the last super shake and tilt, when it can't possibly be saved. I set me tilt pretty tight.
If someone did a bang back or death save on my machines, they would never be invited back. Probably kick them out on the spot.
I have had many visitors, and found most to be courteous and ask how I feel about nudging. I simply tell them dont worry if I think you are nudging to much you can just buy the machine
On a serious note though, my visitor are pin owners which I think understand how much a pin is and how hard it is to fin a nice one.
Quoted from Blakesell:B_R, You have that Ac/Dc on the way, you will have to nudge or slap to get that ball from coming SDTM sometimes. Its just a fact of life to avoid those short ball times. .
That's "randomness" as Gary calls it, personally I like flow, but played ACDC a couple days ago and noticed the same! Ironman is another nudge required game
Quoted from ovfdfireman:If someone did a bang back or death save on my machines, they would never be invited back
And the difference between these two is...?
Quoted from pinballslave:And the difference between these two is...?
Here you go pinballslave:
@ 0:58 = bang back and at about 1:05 = death save
Quoted from system11:I have a flock of waiting ninja who behead anyone who nudges my machines, even gently.
Funny !!
The games were designed to be nudged. All the best players do it...effectively. I have actually shaken balls back up an outlane when they were already partially down. Most recently I seem to recall doing it on SM and BSD. Some games have multiple tilt warnings as a default in the software to allow you to get away with it to a certain extent.
I'm not the best slap-saver, but I've gotten decent at nudging the ball off the top of the slingshots or the post between the inlane/outlane.
Quoted from wesperron:NimblePin said:Carry Over!
Thank we needed that here....wink wink nudge nudge.
A nod's as good as a wink to a blind bat.
I am considering buying these and wearing them while I play. I wonder if they'll help my nudging?
http://www.amazon.com/Title-Boxing-TITLE-Weighted-Gloves/dp/B001152MD6/ref=sr_1_8
Depends on machine.
Sterns like Elvis, BBHP and Indiana Jones are very nudgeable as theres a lot of rubbers for the ball to bounce around. I nudge modern sterns like crazy. I think they're lighter so its easier. I do nudge other games just not as much.
I nudge very rarely. I guess it comes from being over-protective of my pins. At a public place, I'm probably a moderate nudger.
I had a visitor to once play my pins and he was very hard on them. He beat the shit out of my LOTR LE. I was cringing watching him play, for I do not mistreat my pins! I didn't want to hurt his feelings by asking him to stop, but I was really glad when it was all over with!!! I don't want a lot of jarring or slapping around on my pins! Might loosen something up and next thing you know you've got something broken or not working.
I rely on my flipper skills with MUCH less emphasis on shaking and quaking them.
I guess I might not nudge a Sega, the playfield might fall off the rails or it might spontaneously combust or suddenly split into two exactly even halves or melt.
Quoted from Pintucky:I had a visitor to once play my pins and he was very hard on them. He beat the shit out of my LOTR LE. I was cringing watching him play, for I do not mistreat my pins! I didn't want to hurt his feelings by asking him to stop, but I was really glad when it was all over with!!! I don't want a lot of jarring or slapping around on my pins! Might loosen something up and next thing you know you've got something broken or not working.
That wasn't me was it?
Look at the force used in moving them, and especially pulling out the PF's on DE/sega/sterns. That always makes me cringe, as they are not on smooth pull out tracks as with WPCs. Nudging, even tilting will not hurt a thing.
Quoted from BLACK_ROSE:DM with the Up-Rite Handles is the Perfect Tool's to Nudge with .. I Don't move the Pin to much tho .
You shaking a DM with the handles must look violent
I'm probably in the large minority, but I never nudge. I don't like jarring my pins. I know they're built for it, but I just don't like it. I get nervous something is going to break.
Although i'm buying a pinbot this weekend and we'll see how long my non-nudging can continue.
I find myself nudging more and more... Usually just a warning or two, but I rarely tilt. IM really got me into nudging. You have to nudge and bump that one, especially on slow returns from the orbit, or you will be cursing in no time....as it drains in some impossibly crazy and almost magical way.
When playing location games: Average nudger, rarely tilt
When tilts are set tourney-tight: above average nudger, often tilts
I do the same amount of nudging, but those tight tilt settings kill me
As a somewhat new pinball player I have recently discovered that I can use nudging successfully while playing. Literally maybe two days ago (I've been playing on average 15hours a week of pinball) I kind of just felt it come naturally into my play. If I see the ball coming SDTM or even at an angle but heading down the middle I can nudge and sort of glide the machine a bit to the right or left (I push left or right, towards the opposite side the ball has a better chance of hitting. If its coming SDTM but maybe ever so slightly to the right, I'll nudge left, pushing the machine left and therefore the ball will catch the right flipper.
It's odd how nudging came into play for me...it was very natural. I just kind of started doing it..it felt right.
I have been having a difficult time getting better at pinball in general since I started playing about 3 weeks ago. I felt like I hit a brick wall skills-wise, but in the last few days I started nudging and starting getting a lot more aggressive with catching the ball, and passing it to the other flipper. I feel like my scores have been lower since I've been more aggressive, but it's such an awesome feeling to successfully pass the ball from flipper to flipper, or to nudge and save what would have been a SDTM drain.
Never used to do it, now its become a regular part of my game. I started getting a feel for outlanes, but ive also started nudging forward just as the ball hits the slings. This has helped me get a lot more ball control.
Quoted from pinballslave:ovfdfireman said:If someone did a bang back or death save on my machines, they would never be invited back
It's pinball 101....
I never used to do it then i watched Pinball 101 and learned how to. I never have done a bang back or deathsave and I will not do one on someone elses machine. but I nudge quite regularly and my scores have gone up.
This page was printed from https://pinside.com/pinball/forum/topic/how-much-do-you-nudge/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
