Quoted from o-din:my electric bill is still only $20-$30 a month with over 30 machines. We pop a breaker maybe once a month.
I'm also guilty of still running off of the lines that came with the house. The arcade machines are the real hogs and they're in the garage right by the box so adding circuits there would be a breeze (just don't feel like moving them all away from the walls, that is like 15x worse than pulling pinball machines away from a wall) and the arcade guys freak out about the house burning down a lot more so I'll probably get that done one of these days, but adding lines in the basement sure seems like a challenge since the panel is in my garage on the other side of the house (no basement under garage or even the room next to it) so I'm probably just gonna leave it be, not even sure if the most qualified electrician could pull it off without tearing sheetrock on a wall or three down which is definitely NOT an option.
The whole house's outlets, AC not included, only run on two 15A breakers (it's no mansion), and just for giggles I've powered on 10 arcade machines and 11-ish pinball machines all at once in both rooms and didn't pop anything, so I'm wondering if I got lucky and ended up on both of the breakers instead of just one. So far I've never popped one since my first ever machine ever, no clue how. Hopefully they're not faulty.
