I'm thinking of moving pins to upstairs room. Question is, will 21 pins be a strain on the floor/ceiling over the living room? Catastrophic pin-drop would probably lead to a divorce!!
It looks like the US residential weight standard is a minimum of 40lbs per square foot. But, that also depends on the width, height, and spacing of the floor joists.
http://www.cichlid-forum.com/articles/aquarium_weight.php
21 pins at 300lbs a pin = 6300lbs = over 3 tons.
I have 5 in my dining room (system 11s) and 8 in my living room, 2 in my entry hall along with a 100 CD jukebox. All over my basement with 15 to 20 pins down there at any given time. If my floor joists aren't strong enough to support that...then it needs to fall so I can rebuild it bigger and stronger!! (cue the SMDM music!!)
Phoebe
6300lbs with > 200 sq ft of room space (+/- 10sq ft /game) = 31.5lbs/sq ft. So your good. You would need a large room to hold 21 games.
A king size waterbed is close to 2000lbs, add in dressers clothes and weight of people your probably over 3000lbs in one room.
With seven in my attic, i was concerned too we would end up with them in my bed ...
Invited an inspector, spacing of floor supporting beams is 50 cm so he said no problem ....but, he said .... with get-togethers spread your public somewhat evenly over the whole place, that will be your main concern
Quoted from PINBELL:I'm thinking of moving pins to upstairs room. Question is, will 21 pins be a strain on the floor/ceiling over the living room?
Pinbell,
As I was reading your 1st post, I thought you were going to say -- will 21 pins be a strain on my back as I lug them up the stairs?
The answer of course is a big Yes.
Please get some strong people to help you if you do decide to bring some/all of them upstairs.
Consider using a good dolly to make it easier, remove door off the hinges if necessary ahead of time, etc.
Not worth throwing your back out, or having it fall on you or on a helper.
The more pins you haul upstairs, eventually, the more you will also need to bring back down.
Quoted from TheLaw:Uff, moving games upstairs is the worst.
All in the basement.....which is just as bad if not worse at my house. Tight 90 degree turn on the stairs SUCKS.
I thought STTNG was literally going to kill someone.
Not really http://s298.photobucket.com/user/jgrenuk/library/JoesPinballEscalator?sort=6&page=1
Quoted from Astropin:which is just as bad if not worse at my house.
Yeah i guess it's all how it's set up. My upstairs was moving half the game in the closet, rotating, sliding etc etc...just not enough room.
Quoted from Pinball-is-great:Pinbell,
I have an Escalera! I'll still have help. I'll put them underneath, in case it slips!(;
Quoted from PINBELL:I'm thinking of moving pins to upstairs room. Question is, will 21 pins be a strain on the floor/ceiling over the living room? Catastrophic pin-drop would probably lead to a divorce!!
That can only be answered when several items are identified...size/ spacing/ type of floor joist, construction method, deck surface, to name a few. Unlike a waterbed ( sadly) your weight is not evenly distributed over a large area. You will also be dealing with dynamic load ( people) assuming the games are being played...ALOT of weight randomly put up there.... I would highly recommend hiring a reputable SE ( Structural Engineer)to inspect and provide a stamped drawing of the area in question....had a similar situation when I reworked some load bearing beams in a house several years back....total cost for SE's services with drawing was somewhere around $650.00....a small price to pay (IMHO) to insure everything is good, peace of mind, and accountability......
You stand to risk much more than an angry Spouse if things go bad......safety first...please don't play around with this...good luck.....mark
Since you already have some useful answers, I'll offer this: Keep adding pins until the floor/ceiling collapses. Then rebuild to original specs and install one less pin than it took to collapse the floor.
Steve
Short answer -
Newer house, likely no problem due to building code
Older house, who knows? Have to get a better look at how it was built
Best advice, turn the garage into a game room. Forget the upstairs pain and agony of moving them in and out!
Quoted from RCA1:Short answer -
It probably isn't a good idea to assume even newer houses would hold the weight. If builders used cheap materials, the bare minimum measurements for things, and cut corners, or used a faulty design that wouldn't evenly distribute the weight, there could be problems that aren't immediately obvious.
But yes, older houses can vary much more widely because of the lack of building codes.
Have a bonus room above garage. House built in 2006, room is 13 x 16 feet. Currently have 2 WPC, 1 Sys 11, 2 Stern, plus home gym at 450 - 500lb. Would like to guage if that would work to add 2 WPC and a GNR data east weight wise.....seems it would. There is also a main beam running side to side in the centre of the garage below. Opinions?
At one time eleven up the stairs. Now eight.
Had to install a removable hand rail which makes it a lot easier.
yes, I considered the people as well, with current load have had 10 people up there at avg 200 lb w/o issue. Of course new layout would restrict the amount of persons too. Proposed amount I am looking at would work out probably 10 with weights in lieu of 2 machines. That clip would be from "The Money Pit" I think...
This page was printed from https://pinside.com/pinball/forum/topic/how-many-pins-upstairs and we tried optimising it for printing. Some page elements may have been deliberately hidden.
