I have a Bally Bow and Arrow I'm working on. The playfield was pretty rough so I knew I wanted to do some touching up right off the bat. At this point I'm wondering how much more should I do. How much imperfection should I leave?
When I first picked it up it was pretty ugly. I knew the lower blue area would need to be repainted for sure.
The upper blue area was so discolored after cleaning I figured I'd repaint it to match the lower as well as the center arrow.
So the result was pretty good and really made the playfield pop.
Next worst were the yellows so I did those.
Here is how it looks now.
So the next part I need to do is the "Out hole scores double bonus" area. Question is do I repaint that area and just touch up the other cream colored areas or mix enough paint to completely repaint all of the cream areas to match? Then do I repaint the whole thing?
Even though I have more yellow I didn't repaint the yellow in the outlanes since they're almost perfect. The yellows don't match exactly but I think they're far enough away from the fresh yellow to stick out.
To be honest most of what's left isn't that bad, mostly some minor wear and swirling that couldn't be scrubbed out. Just a few wear spots. The worst spot is above the left flipper- you can see it in the first photo and a preliminary touch up in the third.
Take for example this area:
Do you think areas like this should be repainted or just leave them as is? My thinking is it will never be perfect... it's not a collector's piece and I have no sentimental attachment to it. Or will I regret not doing a full repaint later on? I'm on the fence.
