Is it some kind of thermal cut out? From CC Bullseye Baseball
Quoted from dr_nybble:Is it some kind of thermal cut out? From CC Bullseye Baseball
That would be my guess.
My guess would be that the top switch blade is a bimetallic strip and when current flows through the wire coil it heats up and opens the connection. Something like that probably.
It looks like a bi metal strip. Is it in the bat coil circuit? I’d assume based on the name it’s there to open the circuit and prevent the coil from being energized too long and burning the coil.
I’d say it is — I looked at it with a magnifying glass.
My grandfather was a rock collector, we used to have a big hunk of asbestos in the house.
I don't think it's asbestos. It's more likely to be a ceramic compound made of aluminum oxide...similar to a spark plug. This would prevent the heat transferring to the wiring and creating a fire hazard.
Might have asbestos in it? It looks a bit furry. I could believe ceramic though, it sort of looks like cement on its edge.
This page was printed from https://pinside.com/pinball/forum/topic/how-does-this-work and we tried optimising it for printing. Some page elements may have been deliberately hidden.
