I am trying to confirm how I think a score motor operates. I believe that if a switch on the score motor is supposed to be normally open, that is its state when it is in the trough of the motor, and when it is on the cam (not in the trough), it should be in the opposite state. Is my thinking correct?
If my thinking is correct, and I disconnect the switch stack from the motor, then the switches should be in their trough state, and if I cycle the switches, by pressing on the cam follower, they should go to the opposite state. Is this also correct?
The reason I am asking is because my score motor runs continuously, and several switches are opposite the state that the schematic says they should be in (mostly, closed when they should be open). I want to adjust the switches, but need confirmation on my thinking before I do so.
This is my first game, and I don't want to screw it up when it (mostly) runs.
