New! Dark mode!
(Topic ID: 282022)
How do you test your light sockets with the machine disassembled?
By Silverstreak02
9 days ago
  • 24 posts
  • 17 Pinsiders participating
  • Latest reply 3 days ago by wayner
    There have been 6 images uploaded to this topic. (View topic image gallery).
    2 key posts have been marked in this topic
    Display key post list sorted by: Post date | Keypost summary | User name
    Post #5 Lamp/socket testing solution. Posted by TheLaw (9 days ago)
    Post #12 The definitive lamp testing solution. Posted by vid1900 (8 days ago)
    Topic indices are generated from key posts and maintained by Pinside Editors. For more information, or to become an editor yourself read this post!
    #1 9 days ago
    My current project is in several pieces. I’d like to test my light sockets before it goes together. The schematic says they are supplied with 6volts (AC?). What do you use to test them?
    #2 9 days ago
    Lantern battery. Model railroad or race car transformer ( set voltage low ).
    #3 9 days ago
    Testing sockets on the bench might identify some hard failures, but intermittent sockets might not reveal themselves until they get jostled by the vibrations of a playing game. No harm in testing ahead of time but you might find more issues once the game is back together and working.
    /Mark
    -1
    #4 9 days ago
    Stick your finger in it....
    #5 9 days ago
    Found and old 5v plug, strip wire, plug in, connect to lamp string. Can also us it to set up a lamp test if you're bored
    #6 8 days ago
    I wired up an extra gottlieb transformer, with appropriate fuses, to some wires and alligator clips. I also put a socket on the board, similar to what thelaw did. It got me 95% of the way there on my williams woodrail. There will always be some sockets that will try your patience.
    Good luck,
    Dave
    #7 8 days ago
    You can judge a socket by just twisting the base or the tab. If loose they is bad...
    #8 8 days ago
    Quoted from pinhead52:
    Which is the case with about 75 percent of Gottlieb sockets. Especially those on those bars. Awful.
    I use a lantern battery
    #9 8 days ago
    I use a good ole 9volt battery goes on smoke detectors, etc. Gottliebs are better then Bally that is for sure.
    #10 8 days ago
    You can judge a socket by....
    ...No means
    #11 8 days ago
    I already had this,
    Power Probe running off my adjustable power supply to test 6v & 12v bulbs, flashers, Led's.
    and have also used & tested mech units in the machine or bench testing mechs & electric motors/gearbox's after rebuilds
    you can trigger pulse the supply for accurate testing.
    this is something similar on ebay.
    ebay.com link » Automotive Power Probe Digital Multi Tester 6v 12v 24v 4 Professional Mechanics
    #13 8 days ago
    Quoted from weeze:
    I note that a lot of people complain about Bally components, but I have never bought Home a wedge head yet they didn't need at least 8 to 10 or more of the sockets replaced because they were just too loose and would flicker brighter and dimmer, or on and off. Gottlieb bought a few batches of questionable quality sockets at one time or another.
    #14 7 days ago
    If your having to go through all that trouble to make some sort of testing rig then I'd just replace them and that way there are no second guesses, and once it's done you'll be good for a life time. To replace a socket with the bulb is about $1
    John
    #15 7 days ago
    Just a thought, but if you supply 6 volts to a lamp socket, is it possible that the voltage will reach the transformer, which would step the voltage up to 120? I’m wondering if the power switch was turned on, would there be 120v at the wall plug?
    #16 7 days ago
    Wallwart transformers have 2 windings, primary (120v) and secondary
    The two do not meet internally
    #17 7 days ago
    Quoted from Dayhuff:
    If your having to go through all that trouble to make some sort of testing rig then I'd just replace them ....
    Trying to process how splicing a wall plug is more work than replacing 20+ sockets
    #18 7 days ago
    I test all the lamp circuits while the playfield is still on the rotisserie
    Much easier to troubleshoot bad sockets/bulbs/wires while outside of the game
    #19 7 days ago
    Quoted from TheLaw:
    That is true, but then if your already taking them out of the game and hooking them up on a jig of some sort then why not just replace them? Old lamp sockets are just to finicky, especially the Bally ones as we all know. Williams on the other hand I never have a problem. I'd just rather not deal with sockets that you get working and put the playfield down and the lock down bar on it's out again. Once you get into the rhythm of replacing them they go pretty fast. For $1 each you'll never have to mess with it again.
    John
    #20 7 days ago
    Quoted from jasonspoint28:
    Excellent point. If you apply 6 volts AC to a light socket that is connected directly to the game's transformer (a GI light socket for example) you can get 120 volts on the other transformer winding and at the wall plug.
    A transformer is a pretty simple device. It's just some coil windings and an iron core that magnetically couples them all together. Usually 120 volts AC is applied to the primary winding which is stepped down to safer voltages used in the game (e.g. 25 or 50 volts and 6 volts) that appear on the secondary windings.
    If instead you applied 6 volts AC to the 6 volt lugs of the transformer it would step it up to 120 volts on the primary winding and 25 or 50 volts on the other secondary winding too. Since the transformer is just coils of wire there is nothing that enforces the direction of the energy transfer so it works in both directions.
    Note that there wouldn't be much current available at the generated 120 volts but the voltage would be there.
    I actually tried this out after reading your question. I tied the 6 volt lugs of a Gottlieb transformer to the 6 volt lugs of a Bally transformer and sent 120 volts into the primary winding of the Gottlieb transformer. I got 120 volts on the Bally primary winding and 50 volts on the other Bally secondary winding.
    /Mark
    #21 7 days ago
    I see the confusion now...No you're not removing anything.
    To test the strings all is takes is plug and bare wire/alligator clips.
    The wood block in my pic is for testing bulbs, and us a separate device.
    #22 7 days ago
    I use the transformer and alligator clip rig.
    Also, most of the time I run around and solder all the playfield lights shut. I get out my dremel and clean up all the tits, then I hit the interface between the socket body and the base. After that I whip out my big iron - I think it is 45 watts and hit them all. Maybe takes me 20 minutes. Then, no flickering on assembly.
    #23 3 days ago
    $5 6v battery
    Got it over a year ago and has helped me with several projects so far
    B04C147B-BF5E-4DE5-BFFE-7064D9185FD8 (resized).jpeg37721085-F60B-4523-B4C5-DE062556B72A (resized).jpeg
    #24 3 days ago
    $ 6.50
    $ 99.95
    pinballmod
    Cabinet Parts
    Troxel Repair
    $ 4.49
    $ 5,899.99
    Music City Pinball
    $ 5,899.00
    Classic Game Rooms
    $ 130.00
    $ 14.95
    COINTAKER.COM
    $ 69.99
    G-Money Mods
    $ 58.00
    Chrome Candy
    $ 99.99
    Full Tilt Pinball LEDs
    $ 19.95
    $ 48.00
    $ 29.95
    Apparel - Unisex
    The GameRoom Store
    $ 89.99
    Game Room Info Shop
    $ 89.99
    € 60.00
    Creo Pinball
    $ 7,999.99
    Music City Pinball
    $ 14.95
