Quoted from PinballFever:Thanks Marcus! I've been there and it's a great source for repair/cleaning tips but I was thinking of cleaning as in making the game look clean and shiny like new so it can reside proudly in your home instead of a dirty basement or garage.
Ah. Well, I can help you with some of that. Unfortunately, it is not a simple request. There are lots of steps involved.
Of course, the easiest path is to hire a restoration professional to restore your game. That takes the most money, but is the simplest method. The restoration professionals will do all of the steps necessary to bring your game to a "like new" appearance.
If you insist on doing it yourself, then you need to start doing your research. Because you will need to learn how to remove your wire loom for cleaning, strip a playfield so that you can clean it properly, prep a cabinet for a repaint, remove lamp sockets, remove staples, remove large metal pieces like the coin door and side rails so that you can either replace them or properly restore them.
What you are attempting to do is very time intensive and requires a very patient mindset. It will not be an as
A great thread for research purposes is https://pinside.com/pinball/forum/topic/vids-guide-to-ultimate-playfield-restoration
The first rule of getting your game "shiny & new" is a willingness to break down your game. In order to properly clean the dirt that has accumulated over half a century, you will need to remove parts from your game. This occasionally means desoldering the wires, unscrewing metal braces, breaking down solenoids, etc.
If you are not yet willing to break down your game, then your cleaning will only be as good as your rag can reach.
With that said, you will need to invest in some items to help make your game as shiny & news as possible.
Here are some items that you will need to acquire:
01. Metal Tumbler -- typically found in gun stores
02. Walnut Media -- used in tumbler as the abrasive medium for cleaning your metal parts
03. Flitz polish -- used in tumbler
04. Small metal pick -- used to remove media from tumbler
05. Mother's Mag & Aluminum polish - used for cleaning side rails and really large metal pieces
06. Simple Green -- used for cleaning dirty from an assortment of item
07. 400 grit sandpaper -- used for cleaning brass rivets on stepper units.
08. Industrial degreaser -- used for cleaning wire looms
09. Magic Eraser -- Used for deep cleaning an EM Playfield
10. 91% Alcohol -- Used for deep cleaning Playfields, stepper units, relays, basically any metal that is grimy and dirty.
11. Carnuba wax -- Used to wax your playfield
12. Novus 2 -- used to clean your playfield
13. Digital Camera -- used to take thousands of pictures so that you can put stuff back together
Once you have acquired these items, I recommend that you start with the playfield. Strip your playfield down to the wood. Then use blue painters tape to cover all the holes. Then use magic eraser/alcohol for a good deep clean. Then wax the playfield with a carnuba wax. Then put your playfield back together.
Once you have completed the playfield, then you can switch your focus to other cosmetic restorations.
It's a long journey, but I feel that you will be very proud once done.
Good luck!
Marcus
