They don't just pull straight out?
Looks like you've got one missing on the bottom left, should be able to get a good peek into the socket to see how they operate.
-Hans
You want them snug or they will fall out all the time. Just grab the socket piece firmly, particularly when putting the new bulb in or you might have to reflow cracked solder.
You can find just about any socket here:
http://www.pbresource.com/sockets.html
Also consider replacing with LEDS. Yes they do make them that plug in these sockets.
Couldn't find the 555 right angle PCB mount sockets here.
Get the #24-8804. Just run and solder a solid wire up from the board below on each side. The right angle sockets can't be found or at least I can't find them anywhere.
I have those in my Corvette and they go in tight also. Look real nice. Just watch, the superbrights are maybe too bright in the white and yellow inserts down by the flippers. But that will be personal preference.
I was thinking about some of these .. many of them can be angle adjusted and fit that T10 wedge. I'm sure you can find them on other places too.
http://bayareaamusements.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=LEDBULB
Yep that boards from a STTNG alright: just pull them out -
here is mine with super brights from cointaker - if you are interested I have a full list
I created with what I put where.
http://evolvestudios.com/sttng/
http://evolvestudios.com/sttng2/album1/
http://evolvestudios.com/sttng/sttn2/sttng2.html
thanks for the list. I am gonna try the spot light behind the lock sign to light up the romulan ship.
These type bulbs are known as "Pinch Bulbs" in the automotive world. Just thought i'd throw that out there.
TZ ben - spotlight is best thing I did - makes it look great - have a green super bright in there and I wired it right into the GI underneath that area - its hidden perfectly
In the pictures I just had the spotlight mocked up with the wires hanging - they are all wrapped and tucked away now with the light lock wiring. and you dont even know its there.
This page was printed from https://pinside.com/pinball/forum/topic/how-do-you-change-this-light-bulb and we tried optimising it for printing. Some page elements may have been deliberately hidden.
