(Topic ID: 221064)
How do I test the ground? Flash Gordon - Aftermarket Power Module
By Toasterdog
5 years ago
  • 9 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by timab2000
#1 5 years ago
I have a test pad for the ground on the power module board. How would I test this? Normally I put the black on the ground braid and red on test pad. Would this be the same for the test?
and what setting on my multimeter to test the ground? Thanks
Trying to solve no backbox lights. My TP4, general illumination was good at 7.5vac. TP3 was high at 15.5 compared to recommended 11.9vdc.
#2 5 years ago
I think the test pad is more for providing a ground to test the other points with. Eg, you'd put the black on the pad. If you get a different reading with the black on the pad than the ground braid, you've got an issue. You could also test continuity or resistance between the ground pad and the braid.
No backbox GI and controlled?
#3 5 years ago
Quoted from Toasterdog:
Wires leaving rectifier J4 P1 and P4 should be almost zero ohm resistance to your ground test point on the rectifier board. This is the GI return for the backbox lamps.
Wires leaving rectifier J4 P8 and P9 are the GI bus. Measuring AC volts you should see 6.3vac between the ground test point.
Wire leaving rectifier J3 P11 is the switched illumination bus. Measuring DC volts you should see 6.3vdc between the ground test point.
This is normal. The big filter cap on the driver board keeps the voltage up near the top so the DMM reads high. The lamp voltages will often be over 6.3v ac/dc in these games too with the later rectifier/xfrmer setup.
#4 5 years ago
Quoted from zacaj:
That makes sense. Thanks. It would have been pretty cool though.
Quoted from zacaj:
I have no backbox lights and no sound. Controlled lights seem okay.
#5 5 years ago
Quoted from barakandl:
I'm really new to the multimeter (if my first question didn't give it away, lol)
I put the red probe on the pins where it (the wire from rectifier board)connects to the boards in the backbox? and then the black probe on the ground pad on rectifier board.
#6 5 years ago
Even the controlled lights in the backbox?
#7 5 years ago
Quoted from zacaj:
If the controlled lights are the flashers, then they work. Flash Gordon flashes on and off. The strobe does not work. It did, it’s an aftermarket red strobe board.
So my issues. No backbox lights, no strobe, no sound. I believe the sound is related to the backbox lights. But I’m trying to tackle lights for now and hoping that resolves the others.
For back story. The cab was restored. When I was putting everything back together I mistakingly switched the backbox lights and the small strobe transformer on the rectifier board. I believe they are plugged the same. Stupid mistake I know .
When I plugged the game in I saw a wisp of smoke from display number one. I can see no physical damage. The original displays did not work after my error, but have now been replaced with LED ones and work fine. The rest of the game appears to play fine.
I’ve always been afraid of the multimeter, but I am ready to fix this for once. I spent a lot of time restoring and I would love to get this back in action. I have replacements for all the connectors, but haven’t done anything yet.
#8 5 years ago
If the GI in the head is out the sound board will not pass the voice chip test (head gi makes the -5v on the S&T).
follow the gi wires back to the transformer board. you have an open circuit somewhere. DMM can help by measuring continuity, beep, with the power off. Can also read the voltage at different point to help isolate where it drops out at. GI in these games is AC to ground... black lead on ground (braid is usually easy place to grab onto for simple testing)
#9 5 years ago
I'd say pull all the fuses and check to make sure you did not blow one when you hooked it up wrong.
$ 22.95
$ 7.00
$ 29.00
RoyGBev Pinball
Hardware
Volcano Pinball
$ 99.00
Berkeley Springs, WV
5,000 (OBO)
Houston, TX
$ 179.00
7,995 (OBO)
$ 5.00
Hardware
Volcano Pinball
Hardware
Volcano Pinball
Retro Electro Designs
$ 69.00
Pinball Pimp
Hardware
Volcano Pinball
Playfield - Plastics
Troxel Repair
$ 18.95
$ 29.00
RoyGBev Pinball
$ 22.50
$ 90.00
$ 9.00
Cabinet Parts
Third Coast Pinball
This page was printed from https://pinside.com/pinball/forum/topic/how-do-i-test-the-ground-flash-gordon-aftermarket-power-module and we tried optimising it for printing. Some page elements may have been deliberately hidden.
