I want to replace light bulbs in my backbox but don't want to take off the actual brackets and remove everything if I don't need to. With the back door off and the lever opened all the way at the top, the mechanical panel only tips back about 3/4". The backglass moves with the panel but the assembly is stopped at the top by two metal L-brackets that are between the panel and the glass. I can't remove those brackets with the panel closed or in that position. If I remove a scoring reel so I can try to push the glass forward as I tip the panel back, it doesn't move away from the panel at all. Am I missing something that is holding the glass to the panel or do I need to remove the bottom brackets that the panel is supposed to swivel on and take out the entire assembly?
