Put the part in a vice, and knock out the roll pin with a roll pin punch.
You can get a roll pin punch set for around $10.
Something like these would probably work:
https://www.amazon.com/Grip-Roll-Pin-Punch-Pieces/dp/B003L7HOMG
Quoted from ForceFlow:Put the part in a vice, and knock out the roll pin with a roll pin punch.
amazon.com link »
https://www.harborfreight.com/8-piece-punch-set-93424.html
Awesome! Thank you very much!
Best,
~ja
Small world @uncle_jose, I asked this same question on Facebook on Saturday. Got the same answer too. Hey, are your coil stops removable with a lock nut, or are they one piece with the bracket? Mine are one piece, but I've heard the original hardware was the kind where the stop was attached to the bracket with a lock nut. That sounds like a better design.
Quoted from Boise_D:Small world uncle_jose, I asked this same question on Facebook on Saturday. Got the same answer too. Hey, are your coil stops removable with a lock nut, or are they one piece with the bracket? Mine are one piece, but I've heard the original hardware was the kind where the stop was attached to the bracket with a lock nut. That sounds like a better design.
Actually my coil stops are not removable. I was able to fix it by using the roll pin tip mentioned above. All is good!
TIA!
~ja
This page was printed from https://pinside.com/pinball/forum/topic/how-do-i-3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
