I have a Gottlieb super soccer that is missing the coin door mechanisms. Is there any way to start the game through a relay? Or something else?
you are gonna need to track down a wiring harness eventually, it is kinda needed...
in order to do what you want, you'll need a schematic... you'll need to jump at least one of the connections on the jones plug receptacle, as well as wiring in a temp start switch...
Manually activate the Start relay that is on the bottom board. Just press it in so the switches close. This should start the reset sequence. Do you have the manual? - it goes through the steps of the reset sequence.
Without the coin door harness present, the 'bounce switch' that would normally be on the door (and closed) will appear as open, so the start relay won't get any power (nor will the rest of the 25V circuit).
This will be shown along the bottom right side of the schematic, along with the color wires on either side of that switch. Those are what need to be jumpered closed.
But before powering up a game that's incomplete and of unknown condition, I'd really suggest getting comfortable with the schematic and understanding how to review the state of the game first (not to discourage you, but keeping safety in mind).
Quoted from DirtFlipper:But before powering up a game that's incomplete and of unknown condition, I'd really suggest getting comfortable with the schematic and understanding how to review the state of the game first (not to discourage you, but keeping safety in mind).
< nodding head "yes" very vigorously >
Yes I checked wires and made sure all joints were hooked up.
Plus I never work on a machine while it is on unless I have to
I wired the machine and got .3 volts ac on the start relay mechanism and 4.85 on the jones plug.
Is that normal?
You'll actually have 110volt line voltage for the start switch...and then 30 volts for the slam switch. You need the cir diagram
Quoted from pinhead52:You'll actually have 110volt line voltage for the start switch...and then 30 volts for the slam switch. You need the cir diagram
i believe only 25v to both... no 110v to the door on that vintage machine, unless this one is different from others?
there may be 110v to the start relay though (i don't have the schematic in front of me, i'm not sure what the reset requirements are)... easy enough to tell by looking at the line voltage leg of the transformer on the schematic...
read and follow the schematic... i'll be blunt, since we danced around this a couple times already... before you go and try to jury rig this up, you need to understand exactly what it is you are doing and why you are doing it... if others have to tell you what to do (i.e. you can't figure it out by reading the schematic), you probably should not be trying it...
sorry for the bluntness... but i don't want to see you electrocute yourself... something like this is potentially more hazardous than simply troubleshooting a problem...
your best bet if you cannot read your schematic is to wait until you get a wiring harness... actually, your best bet is to wait until you get the harness and get the machine back together... i see you are making progress towards the "putting together" part that in your other thread...
I understand the schematic it's just the wires coming off the fuses don't match up. Or at least it's hard to tell
Unfortunately the motor controlling the game won't stop now and the thing is stuck in an endless cycle
Now that is the best way to fix your problem, new door!!!!!!!!!!!!
Quoted from Zsuttle:Don't worry I got the whole coin door harness and mechanisms for $30 off of ebay
This page was printed from https://pinside.com/pinball/forum/topic/how-can-i-start-a-gottlieb-pinball-without-a-coin-door and we tried optimising it for printing. Some page elements may have been deliberately hidden.
