(Topic ID: 160782)
How can I remove a scratch from LCD monitor?
By merccat
6 years ago
  • 14 posts
  • 10 Pinsiders participating
  • Latest reply 6 years ago by setzkor
#1 6 years ago
Greetings all!
I just got my NIB WOZ ECLE this evening and have been really enjoying it. After getting my initial games in I decided to update the software and while taking the time to closely examine things I noticed what I thought was a hair on the back glass. When I looked closer I saw that it was actually a scratch on the monitor underneath the glass. When I removed the back glass I could also tell that I was not the first to notice since with the glass off I could see there were smudgy finger prints across the scratch where I guess someone tried to rub it out with their finger. So while it's a little disappointing that the scratch was noticed at the factory and not handled there I totally understand that things happen it was probably small enough to not trigger any action. After all it's barely noticeable and had I not been staring at the screen watching the update I probably would never had noticed just playing the game.
So my question is, is there a safe way to remove a scratch from the WOZ LCD screen? I guess it really applies to any LCD screen. The scratch is small (about 1/2" long but deep enough that running a soft cloth over the area i can feel a slight ridge.
#2 6 years ago
Bring it up to the manufacturer? I could see this solution being met with mixed results and I'd probably just do something lesser like you plan to do but it would bug me and if there's no better/easier solution I'd try that. Not like they have to replace the whole game.
#3 6 years ago
What Otaku said... Or Novus #1 maybe? I'm not really serious about the Novus 1, at least not with some verified, credible opinions to second mine.
#4 6 years ago
The face of most LCDs is textured to cut down on glare, so if you polished out the scratch, you would have a shiny spot on the monitor (that would draw even more attention to it).
It will probably have to be replaced by JJP
#5 6 years ago
Dang, I was hoping I would be able to handle it myself. It's just one of those things that once you spot you get drawn to. It actually bugs me more that it bugs me if that makes any sense lol. I give them a call and ask about it but honestly it's pretty minor which Is why I was hoping I could just do something myself. Yeah, I could see how polishing could easily make things worse... which is why I wanted to ask before trying anything lol.
#6 6 years ago
Antiglare coating makes it impossible to fix in a way that will be better than what you have right now.
#7 6 years ago
the stuff you need would cost 3-4X a new monitor. for glass you need wet sanding sponges from 100 grit to 5000 grit, polishing pads from 2000-5000 grit and a bag of tinoxide to make a polishing paste and it takes hours. i think you would destroy an lcd with the pressure you have to apply to it. i have these glass showcases in my restaurants that cost upwards 5-6k each ( 2 per location , 3 locations) and little shits will carve all kinds of dirty words in them when no one is peeking so i bought all this stuff to save the 1000.00 deductible3-4 times a year.
#8 6 years ago
Not saying to do this, but if you have no choice...Novus 2 can make it look better.
I got a 32" lcd tv for $40 because it had really bad scratches in the middle. It looked like movers scraped it against a cinder block (repeatedly). I polished it with Novus 2, with light to medium pressure. Novus removed the scratches, but did leave a shiny spot. The spot is only noticeable when the TV is off. It looks great when it is running. It was a huge improvement. But this was a bad, bad, case, where the TV was a lost cause before I did anything.
Again, not saying to do this, but I'd start with a fraction of a drop of Novus 2 on a q-tip, take a small swipe over the scratch, then gently wipe off. If the scratch is still noticeable, then continue to work it until it improves, or I'm convinced I can't make it any better.
#9 6 years ago
Fortunately (or unfortunately) it's not the glass that scratched, it's the actual monitor which is more of a soft plastic with a matte finish.
When I called support they were pretty amazed that had happened and they asked for pictures which I sent over. Their initial recommendation was to give Novus 1 a try so I'm starting small with Novus 1 sprayed onto a microfiber cloth, then gently wiping the scratch area with it. I would be surprised if 1 did anything though since it is deep enough to feel when I touch it.
#10 6 years ago
Quoted from merccat:
It will need to be replaced, surprised support recommended novus
#11 6 years ago
Well I can report that after about 5 minutes of relatively firm polishing, Novus #1 does not seem to damage the LCD's finish. I still would not recommend it for any normal use on an LCD but if you have a light scratch it seems safe to try. It also seemed to reduce the ends of the scratch reducing it's length by probably 1/8", but the deeper area is still there.
#12 6 years ago
Well support has opted to replace the monitor. So in the end of this case yet another story of how on top of things JJP support is. My impressions from this experience and reading others is that not only are their machines top notch but so is their customer care.
Still kind of curious if it would even be possible to remove though... I think I have a junk LCD computer monitor around, may experiment with more aggressive polishes (ie Novus 2) on that.
#13 6 years ago
Good news!!
#14 6 years ago
Yikes... Novus on the front polarizer surface of an LCD is not going to do anything good. At best you will remove the anti glare coating on that area leaving a shiny spot as Vid mentions. If you go deeper hitting the TAC you could damage the polarizer itself causing new artifacts, color etc. One option is to laminate the full surface of the display with a new film (think mylar). The adhesive should wet out the scratch and then the whole surface will be the same "texture"... Likely glossy. Think screen protector for cell phone but more of a pain in the ass.
The best and only realistic option is full replacement as you are getting. Or of course trying to ignore the scratch.
Other
$ 6.00
Pin Monk
Other
$ 235.00
Pinball Mod Co.
Toys/Add-ons
Precision Pinball prod.
Flipper parts
$ 22.50
Magazines/books
Pinball Magazine
Magazines/books
Men
This page was printed from https://pinside.com/pinball/forum/topic/how-can-i-remove-a-scratch-from-lcd-monitor and we tried optimising it for printing. Some page elements may have been deliberately hidden.
