Quoted from PopBumperPete:How can I practice soldering?
I can solder a wire back onto a coil or a switch blade
But I want to install sockets so I can add a ‘anypin NVRAM’ to the MPU board on my CFTBL
As I do not want to mess the board up, any suggestions as to how I can get some practice soldering small pads?
Pete
The FIRST and MAIN - for what you want - problem is, to get the old RAM-Chip out of the board. The DESOLDERING is the main problem. If you have no experience there, you can destroy your cpu-board more when soldering the new socket for the NVRAM in.
Hakko 808 is the best tool for desoldering.
I have made a few years ago a (bad) video how to desolder the old RAM-chip on a WPC-CPU-Board without a desoldering tool - the poor mans primitive way, but works perfect - you only need a needle (0,6 mm) from your pharmacy, a small srew driver and an electronic pliers.
So, if the old ram is out, soldering in the new socket is pretty easy, when you exercised a bit before.
BUT be very very careful, the traces and VIAS are VERY delicate; if you do not trust in your own work, let it do an expert, because the CPU-BOARD is too precious.
Heres are the videos:
PART 1:
PART 2:
As I got some critics from german users, that I used the wron pliers and better should use a knife or even a dremel, I made another video, to show the differences - make your own choice, what is best - I prefer the method with my favorite pliers. Here we go:
Do NOT use desoldering raid or a primitive desoldering pump, your vias will flow. Use either a Hakko 808 or my primitive method - thats my opinion.
Good luck ....
- Ingo
