I have a Pistol Poker that seems to cause an issue with new players.
When you launch a ball, the ball goes down the shooter lane to a scoop that sends it up to the upper playfield. There's a thin spring steel flap on the play field that forms a one-way gate. The problem is that if you underpower your launch the ball gets stuck between the PF and the flap. It would seem impossible to do, but it happens to EVERYONE that plays the game for the first time.
I have a custom made 'poking stick' that I use to dislodge the ball. This is a HUGE PITA because the steel is so strong it holds the ball fast and it cannot be shaken loose. I must pull the glass to poke.
I don't know of other games with a flap like this, but they must exist. Ideas?
The hole is clean; the flap is clean; the ball is clean.
PLEASE HELP!!!!!!!!
faz
