(Topic ID: 334070)
Hotdoggin’ right flippers dead
By EMDude
1 year ago
  • 9 posts
  • 6 Pinsiders participating
  • Latest reply 1 year ago by BigAl56
#1 1 year ago
My Bally Hotdoggin’ has been working great, then both flippers on the right stopped working. I checked all wiring and found no loose connections. Filed flipper button contact as well. Thinking it might be Driver Board related, I swapped out the board with a new Alltek and no change. Put existing board back in and cleaned pins on J1 & J2 and checked/wiggled connections while holding down flipper button, nothing.
Next, I tried this from minnesota13 on another post: “Run a clip lead from the working flipper coil voltage in -- the end lug with the diode stripe to the equivalent lug on the non working flipper.
Then if the non-working flipper now works it's the flipper power pin associated with the driver board. If it doesn't work look for a ground path problem.”. I get nothing on either right dead flipper which tells me I may have a grounding issue?
How should I troubleshoot this problem further?
As always, THANKS!
F2E280D5-45AE-473D-A13F-3826B0DC0B4A (resized).jpegF2E280D5-45AE-473D-A13F-3826B0DC0B4A (resized).jpeg
#2 1 year ago
If you hold in the flipper button and manually lift the lower flipper does it pull in and hold? If so, file or replace the EOS switch.
If the flipper won’t pull in and hold, inspect your original driver board for burned traces. If they are burned, the new driver board may be damaged too.
#3 1 year ago
Thanks for your response. I’ll give that a try but there are two flippers on the right side, both dead, and unlikely the EOS switches failed simultaneously. Also I swapped the driver board with a new one and it didn’t correct the issue.
#4 1 year ago
Quoted from EMDude:
... two flippers on the right side, both dead, and unlikely the EOS switches failed simultaneously.
For sure. Do you have the schematic? Trace the power backwards.
#5 1 year ago
Not sure if there are fuses on the flipper power/Ground for this machine but that is a good place to look. I made the mistake of replacing a coil and diode once, then figuring out after the fact I had a bad fuse even though it visually looked good.
#6 1 year ago
Check the switch stack at the lower flipper. I believe the switch on the right is normally closed. Neither of the right flippers will work if that one has any gap.
#7 1 year ago
Problem is going to be with the lower flipper as it flips the upper flipper. Could be a broken coil wire or a bad EOS switch. Post a few photos that clearly show the EOS and coil wiring. If the switches are original this might be a good time to do a flipper rebuild.
#8 1 year ago
Fixed! ghostrachel BigAl56 yep, it was the normally closed switch on the lower flipper. Filed it and the EOS and everything works again. Yes, I will be rebuilding these flippers soon. Thanks all!
B36C057C-9E33-4B9E-B32C-D6AB20EA39C9 (resized).jpegB36C057C-9E33-4B9E-B32C-D6AB20EA39C9 (resized).jpeg
#9 1 year ago
Definitely rebuild that mess. Also note the amount the flipper shaft extends through the crank is too much. Either wrong flipper or improper setting. Flipper shaft should extend through just a small amount and there should be nominal vertical play.
$ 44.99
Pinball Shark
$ 149.95
Allteksystems
$ 18.95
Playfield - Plastics
$ 8.00
Third Coast Pinball
$ 18.00
$ 9.95
Hardware
Volcano Pinball
Cabinet Parts
Volcano Pinball
