So, I finally bought my first pinball table. A 1973 Gottlieb's Hot Shot. The machine works great (after tweaking a tilt relay and sanding some score switches) but there's this goddamn green plastic on the right side of the play field where, if the ball falls or flies up with little to no momentum, the ball will get jammed.
Looking at the issue, I don't know if the rubber is too thick, pushing the plastic outward or if the green plastic is just bowed too far out at the ends creating too much friction and stopping the ball?
Looking at some Big Shot pics, their posts are actually titled inward eliminating this wedge issue and the left rollin lane totally works fine.
I order a new set of rubbers, hoping that they will be smaller but if that doesn't work is there a way to safely soften and bend the plastic back, so it stops blocking the ball.
Thanks for any advice you can offer.
