Hello,
I have a Whirlwind, and a Funhouse that seem to be plagued with the horizontal kickers getting stuck in the "out" position. So when the coil is fired, the plunger will extend to its outer limit like it should, but then it will get stuck on occasion. Also happens more if two balls get loaded. I can shake the cabinet and that will jar the plunger loose, but I would like a better solution.
The sleeves in the coils are brand new. The plunger shafts are clean and lightly polished, and show no signs of damage. Best I can tell is that the round-like weight on bottom of the shaft, is sticking to the angle bracket under the coil. I have dabbed a very light amount of grease on the weight, to discourage it from sticking. That only helped a slight bit. So why does that round weight want to hang things up?
