(Topic ID: 304318)
Hooking up two machines to one POLK sub. What do I need?
By delt31
2 years ago
    #1 2 years ago
    Hey guys - I want to hook up two pinball machines to one polk sub. I want to leave the machines on though (obviously only playing one at a time) - is this possible and if so, what additional hookups do I need?
    #2 2 years ago
    Yeah depending on the polk sub - if its the 10 inch you can hook two games up L/R from both games, keep the volume/phase around the middle.
    #3 2 years ago
    Pinnovators has good products for this.
    #4 2 years ago
    Two games should not be a problem as long as the sub supports multiple inputs.
    Modern Sterns you can run RCA low output directly from the CPU (Node 0) and most others just run speaker wire from the internal sub to the high input on the sub.
    #5 2 years ago
    Worst case scenario you just need a little submixer like a YAMAHA MG06 which will cost you about a hundred bucks. That will allow you to plug in your 2 pins - and another couple of devices if desired - and control the volume for each going into the sub.
    #6 2 years ago
    Not sure which games your are hooking up, but I've had issues hooking up two spikes games to the same sub using alligator clips, weird things happening with the lights. It happens because the ground is being shared across the games. I use the pinnovators pinsub mixer now, which isolates the ground and allows 4 games to be run off one sub with adjustable volume control for each pin. Sounds better and I believe is a safer way to do it.
    #7 2 years ago
    I've got several Polk subs hooked up to two games each. I didn't need anything special. I just took two 6-8' lengths of wire and connected one pin to the sub via alligator clips on the bottom board speaker and inserting the other end into the left or right sub input. Then hooking up a second game in exactly the same way using whichever input is now available - either left or right. I've played both pins simultaneously with no problems. The speaker appears able to handle it fine.
    #8 2 years ago
    Quoted from Lermods:
    I’ve had two Spike games hooked up to one Polk sub for quite some time now without any issues. I wonder why yours had problems? Wonder if I should change up the lineup to avoid two Spikes on one sub?
    #9 2 years ago
    I’m talking about psw 10 so I can hook up both via alligator clips at they can be played at the same time?
    What are the pinnovators product of I want to go that route? Link?
    #10 2 years ago
    Quoted from SNES:
    Not really sure, but I had Elvira and avengers hooked to it. When playing avengers with Elvira off, the coindoor lights on elvira were flickering. Really odd behavior, but I then unhooked elvira from the sub and it stopped. After that, I switched to the pinnovators product. Having used alligator clips forever, I then realized the pinnovators product sounded better and have since switched all my games to them.
    Quoted from delt31:
    Here’s the product for one game.
    https://pinnovators.myshopify.com/products/pinsub-spike-spike2-stern-kit
    Here’s the mixer for multiple games.
    https://pinnovators.myshopify.com/collections/stern-subwoofer-kits/products/pinsmx-passive-subwoofer-mixer
    #11 2 years ago
    Get the mixer. You can go 4 deep. And adjustable for each machine. Done.
    #12 2 years ago
    2 pairs of alligator clips and some 14 gauge speaker wire. Done.
    #13 2 years ago
    Thanks guys this has been helpful. Didn’t know you could connect two machines to one sub and keep them both on
    #14 2 years ago
    I use psw 10 and have them hooked up.to 2 machines each. Sound great even when both machines are played at the same time. No special hook ups-just alligator clips to l and r inputs. If you stop to think about it, in a stereo hook.up, l & r inputs are connected and play fine so why wouldnt 2 pins?
    #15 2 years ago
    Where on the stern sub do you clip to? And where do you run the wire out of the cabinet since there’s no opening under it?
    #16 2 years ago
    Quoted from extraballingtmc:
    Clip to the positive and negative terminals in the speaker. I route mine through the openings in the back
    #17 2 years ago
    Going to order some alligator clips from Amazon- is there a particular one/size/style to get?
    Anyone got a link to ones they’ve used to hook up polks?
    Tia!
    #19 2 years ago
    Anything will work. The clips are to connect to your bottom speaker easily. You could also solder the wires if you dont have clips. On the Polk side, the bare wires just slide into.the slots provided.
    It's not all that exacting a science!
    #20 2 years ago
    Lol ok Txs, guess I’m over thinking it. Just so many clips on Amazon got confused
    #21 2 years ago
    There is a pinsider here that sells them along with the wire already done. I have used 10 kits or so on my games
    #23 2 years ago
    Quoted from Aflacjack:
    I made a few extra sets when I did mine as well... I have 4 sets left
    https://pinside.com/pinball/market/shops/1289-youbentmywookie/04827-10-subwoofer-cable
    #24 2 years ago
    Dang... those sold quick.... If there is enough interest, I could make up a batch of them again.
    #25 2 years ago
    Quoted from ralphwiggum:
    Yours are half the price of the other seller after shipping and 16g vs 18g wire. I'd be interested in two sets if you decide to make more.
    #26 2 years ago
    Quoted from mycarlooksfast:
    10-4.. I will get some more supplies ordered and make up another batch and post here.
    #27 2 years ago
    For the Canadians I just grabbed a 10 pack of alligator clips plus 100’ of 16 gauge wire at the source, with taxes 42$
    This page was printed from https://pinside.com/pinball/forum/topic/hooking-up-two-machines-to-one-polk-sub-what-do-i-need and we tried optimising it for printing. Some page elements may have been deliberately hidden.
