ok so doing everybody's favorite activity SWITCH MATRIX TROUBLESHOOTING,, as right bumper firing causes upper vuk and slingshots to fire, with no balls In trough switch edge test read normal for right bumper with balls in trough get multiple switches reading for r bumper ,
no ball, just r bumper(56) reads when bumper is activated
ball in trough 3 : 56 read and 53 read
ball in trough 3 and 2: 56 and 53 and 52
ball in trough 3 and 2 and 1: 56 and 53 and 52 and 51
ball in outhole : 56 and 50
as well r flipper works but does not show up on switch test , disconnecting c1 connector of flipper board all the switch errors go away, seems like issue with sw16 (/ flipper board ) and short between column 2 and7,
i have checked all the diodes and the trough switches test ok ,, checked the matrix on the mpu board with the play field disconnected all switch readings correct
wondering if there might be 2 or more areas causing this, could a shorted diode pr other malfunction on the flipper board explain part or all of this ? thanks for any ideas
