posted over on hook and data east boards but think better over here in its own thread so when it gets fixed easier for someone else to learn from
newbie to owning a pinball but learning a lot ..., when I got it did a shop job new lights etc and got an easy trouble shooting fix under my belt recent with a blown fuse that looked good . have been happily playing the hook for a few weeks till this
started getting a random outhole firing , did not think much of it ( not uncommon to gave random firings with data east?) now get a slam tilt error when lower skill shot switch activates (switch 31 c4,r7) , slam tilt is on same row c1 r7, checked all switches edge test and active , all seem fine, disconnecting slam tilt and coin door error still occurs, checked switch wiring for shorts and all diodes on the row
started looking in back box to run cn 8 and cn 10 matrix but noticed section of mpu board seems fried resistor 27 fried and chip below seems like it got to hot, board is hazy in the area , as well on board PIA led not lit, on playfield board in cabinet r49,r50,r51 leds not lit
so it seems like I need board work or new board , any sense in checking switch matrix at board?
do these things just happen due to transistor or board component failure or is there some other play field issue I should check?
any recommendations for board guy? thanks !!
