Still not sure how changing a diode on a lamp socket wiped out a bridge
I think it just failed I'm the second owner of this game and almost all the parts in it are original
Could be just coincidence. Stranger things have happened. Let us know how you make out with the bridge
Man this game is fun! The new code is awesome! I’ve been playing it a lot the last week, a couple games around 300 million and then last night 426 million. Tournament mode, no extra balls. Got into multiball 3 times, got to bangarang And scored some good points in the modes like croc time and fast scoring along the way, and got the wind coaster ramp up to some pretty big values. I was a huge fan of the movie growing up. This game really immerses you into the adventure atmosphere with the music, call outs, sword fighting sounds, cannons, etc. also just found out this week that the modes on the right scoop are stackable with multiball. This game is a lot deeper than it gets credit for. I’m really glad that so many people either hated the movie or just wrote the game off because they thought the only way to get points was to spam the ramp. It made it affordable for me and my family, who cares what the pin side ranking is, it’s just pure fun!
Also changed the bulbs on the jackpot ramps to blue LEDs, with all the flashing going on in the game during multiball it can be hard to see what the jackpot is if you don’t know what you are doing, now it really stands out and looks great.
Quoted from bobwiley:parkshow30 you should get a pinsound board for it too
I have heard this recommended, Haven’t looked into it yet. I will have to check it out, thanks.
Parkshow30 good review for me chad code saved this game. I've just got a colour pin2dmd for mine looks great, side art blades too.
Quoted from Parkshow30:I have heard this recommended, Haven’t looked into it yet. I will have to check it out, thanks.
Therea no checking into it. If you loved the movie you must get one. Makes it seem like a completely different game. I was hesitant at first just because the price. After installing it i have never looked back and wondered how did i play it without pinsound.
Quoted from garretswinning:Therea no checking into it. If you loved the movie you must get one. Makes it seem like a completely different game. I was hesitant at first just because the price. After installing it i have never looked back and wondered how did i play it without pinsound.
Now I'm wanting one too. Are the Hook sounds available to download from somewhere?
Quoted from astyy:Now I'm wanting one too. Are the Hook sounds available to download from somewhere?
I can send you the files once your ready for it. Just shoot me a pm. I also have saved files for the shaker kit to go with the sounds. You can add a shaker kit to the pinsound plus board made by pinsound.
I got the colored display and makes a huge difference...
The three things any Hook machine should have is:
1. Be in working condition
2. Chad's code
3. Pinsound
I have a HOOK pinball that my grandfather bought sometime in the early '90s that I have finally got working again. I have changed all the bulbs to LED, got some things repaired on the boards in the back, which controlled the vertical up kick.
Only one small issue is the right flipper is now sticking. I need to buy a rebuild kit for the flippers, but should I also replace the coils?
While I am doing this, can I upgrade the flipper buttons to illuminated buttons?
What is a pinsound, and where do I get one, and how do I install it.
Anything else I should do to this thing?
Quoted from boogieman98:I have a HOOK pinball that my grandfather bought sometime in the early '90s that I have finally got working again. I have changed all the bulbs to LED, got some things repaired on the boards in the back, which controlled the vertical up kick.
I did the colored screen in mine..Made the game look way more modern...
Quoted from kciaccio:I did the colored screen in mine..Made the game look way more modern...
Agreed!
By default Hook only uses 2 brightness levels on the DMD which in that video are replaced by white and red only. Pin2dmd looks better still if you apply a full colouring map - vbobrusev on here has done a great job that he sells. I'm doing my own but it takes weeks!
Quoted from boogieman98:What is a pinsound, and where do I get one, and how do I install it.
Pinsound is a replacement for your stock soundboard. It allows you to have and switch between multiple "soundtracks," callouts for a game, and the volume level for callouts and music. It also has options to use headphones and other things. a new version has the ability to hook up a shaker motor and customize the vibrations to your game. https://www.pinsound.org/
If you haven't yet, upgrade your game's ROM to chad's version. Rule changes, audio changes, etc were all done by him to make the game much much much better.
Do those two things. You won't regret the money spent on a pinsound and the change to the new ROM. To quote a certain pirate, "Have I ever made a promise I haven't kept?"
Quoted from astyy:Agreed!
Its full color....My videos don't really do a good job showing the color spectrum..Looks 10 times better in person..Even has purple...
Hi all! first post here
I am looking for a part-number for the ball trench running from the skull to the scoop. I have one with broken of mounting point and a nice big hole where the ball gets stuck.
Also, what is the generally accepted method of fixing some wood chips off the backbox? Next to that, cleaning cleaning cleaning as this machine hasn't seen any TLC for at least 8 years... (and yes, I removed the batteries, step 1. Thank god no corrosion)
Quoted from erikv:Hi all! first post here
DE Hook Under Chute Assembly DE-535-5156-00
Good Luck!
I found one about 4 years ago at pbresource
I am going to get that PinSound for sure but on the Rom can I purchase a ROM already flashed so all I have to do is install it? Also, I just purchase a knocker as the one in the machine was missing. I went through diagnostic to test it but nothing. Any ideas?
Quoted from boogieman98:I am going to get that PinSound for sure but on the Rom can I purchase a ROM already flashed so all I have to do is install it? Also, I just purchase a knocker as the one in the machine was missing. I went through diagnostic to test it but nothing. Any ideas?
I got mine from https://pinside.com/pinball/market/shops/1083-matt-s-basement-arcade He's great, done a couple for me. He just charges for the rom chip and the burning. Go to ChadH's website to donate for all his hardwork redoing the code. He did a fantastic job balancing the game and incorporating our feedback into the update.
I heard the pinsound with the shaker is awesome. I haven't tried it, but thats the one i would go for.
I'm playing a lot recently on the Chad 5.0.1 code and regularly notice that the Pirate awards aren't awarded for hitting just the top drop target (closest to windcoaster), I have to hit one of the bottom 3 to win it. Has anybody else noticed this? It could be machine specific but I'm sure that target registers as the bank reliably resets to the Cannon animation during normal game play.
Quoted from astyy:I'm playing a lot recently on the Chad 5.0.1 code and regularly notice that the Pirate awards aren't awarded for hitting just the top drop target (closest to windcoaster), I have to hit one of the bottom 3 to win it. Has anybody else noticed this? It could be machine specific but I'm sure that target registers as the bank reliably resets to the Cannon animation during normal game play.
Ive noticed this time to time but thought it was just me.
Quoted from garretswinning:Ive noticed this time to time but thought it was just me.
Interesting, I'll keep a closer eye I've only noticed it on the top target as that's easiest for me to hit, this area is mentioned in the 5.0.1 guide;
"Adjusted logic on Drop Targets to better guarantee that they will register during Pirate Town."
I am shopping a Hook that I acquired recently and have a question about the deflector for the center hole. The one on this machine is cocked to the right (viewed standing at the front of the machine). If the factory mounting holes were used, it would be straight. Has anyone seen this before or is aware of a reason for this?
0226202201_Film3 (resized).jpg0226202201a_Film3 (resized).jpgHi guys,
Andrea from italy here, proud Hooks' owner, spent many year on that game, i once scored something around 676 millions.
I read almost all your threads and i confess i was very pleased of all the quirks and glitches that you reported, only heavy gamers can know that.
Many hours spent with that game and now i'm intrigued about upgrading cpu rom to the 5.01 version.
I'm making some homemade repairments with a friend, and we noticed there's installed a knocker which is unconnected near the cash box, when we tried to connected it started to knock immediately, so we've left it unconnected. Any suggestions? .Can you tell me when the knocker kick in the game?I'm so curious since no one talked about that.
Overall the pinball is in good condition, apart some light that are very dim (1 row), we double check the matrix lamps but it's not easy, i thought i may override the problem using LED.What do you think, is it doable?
Hook Hook HOOK!
Update on my problem with hook ended up being a bad bridge rectifier on the power board and a bad tip 36 c at Q3 on the ppb board I checked all the transistors and I checked all my coils and diodes on the coils had one bad diode on one coil the drop Target coil so after I replace the bad diode the tip 36C transistor and the bridge rectifier put a new fuse in on the power board that was blown from the bridge rectifier going bad I'm sure... plugged it in and fired it up and everything works perfectly thanks for the help guys
Quoted from FiatsRUs:I am shopping a Hook that I acquired recently and have a question about the deflector for the center hole. The one on this machine is cocked to the right (viewed standing at the front of the machine). If the factory mounting holes were used, it would be straight. Has anyone seen this before or is aware of a reason for this?[quoted image][quoted image]
I would imagine bricked shots were going straight down the middle and the angle was adjusted with new screw holes to prevent this.
Quoted from Crash:I would imagine bricked shots were going straight down the middle and the angle was adjusted with new screw holes to prevent this.
I'll buy that! Probably leave it as is.
Quoted from Magellano:Can you tell me when the knocker kick in the game?
The knocker was missing on mine so I installed one, it knocks for Replay, Match and (I think) multiple times for certain hi-scores. Perhaps other things like Bangerang and Victory award, I rarely see those!
Iirc I've read that the knocker circuit can be used for something else (play meter?) others may know the detail.
Quoted from astyy:The knocker was missing on mine so I installed one, it knocks for Replay, Match and (I think) multiple times for certain hi-scores. Perhaps other things like Bangerang and Victory award, I rarely see those!
Imho just with awarding a special. You can use it as spare kickback/laserkick though
I am slowly dismantling my Hook for a cleaning. You literally cant touch anything under the glass and keep your hands clean. Big coat of black dust on everything.
I am going for regular rubber for now but whites. This machine definitly hasn't been cleaned or even looked at since I know of it's existence (8+ years).
So for now the plan is a nice clean+wax, clean out all the inserts from below as there is black dust everywhere etc, full LED upgrade (Gi/flash/Controlled), downhole protectors, DMD saver, some new connectors here and there, fresh balls etc.
Some work on the ball lane below the skull (somebody has had a go on it before, but it needs some metal spotwelded) and to bad there is a hole in the ruffio ramp (but not dramatic yet) so I might get another one from freeplay40
Just updated my Hook to color and it is awesome! Thanks to dpannell for the awesome display and vbobrusev for the great job he did on coloring. It looks very sharp!
I noticed that the scoring numbers seem to have a little ripple in them but went and looked at the earlier videos and they had the ripple in them as well. Was that always that way or something due to the coloring? Honestly, I can't remember how it was prior to putting in the color screen.
Super easy to do!. The hardest part was putting the ROM chip into the display. Had to bend some legs, etc. Other than that, no big deal at all.
Quoted from DBLM:Just updated my Hook to color and it is awesome! Thanks to dpannell for the awesome display and vbobrusev for the great job he did on coloring. It looks very sharp!
Thats supposed to be a sparkle effect inside the numbers. The original dmd had it as well. Congrats on the color dmd! Gamechanger
Quoted from garretswinning:Thats supposed to be a sparkle effect inside the numbers. The original dmd had it as well. Congrats on the color dmd! Gamechanger
Thanks for the clarification. The color DMD is a must have.
Just curious, has anybody put together a good music mix for Pinsound? I put one in my machine years ago, tried to make a mix which sucked, and eventually sold the board.
I’m getting a random reset. When I turn the game on and Tootles says his spiel when he gets to the final 2 words the game resets. It will do this every time UNLESS I plunge the ball before he stops talking. If I do that the game works fine and I can also play all night with no resets as long as it stays on. As soon as the game is off and turns back on the problem starts again. Any ideas?
A week ago the display was scrolling and after checking to make sure everything was seated correctly I found someone that had a similar problem on a medieval madness and they said it was failing caps. I ordered and replaced the two that were failing and the display worked great all week including 4 straight hours of play from a birthday party. Haven’t done anything else to the game recently
anyone knows the nut size on the powerswitch on the bottom? mine came undone years ago so the entire switch can be pushed into the cabinet now
Added over 4 years ago:edit: likely 12mm nut with a fine thread; I
solved
it by ordering a 80 cent 2 pole powerswitch on AlieExpress
I just unpacked my new to me Hook. It plays well until you hit the Skull hole, once it drops in there, it goes dark with “Slam Tilt” on the display. Game over ball kicks out to the drain and you can start over. Playing it a while longer, making sure not to hit that hole and somewhere in the upper play field it will get a skull and crossbones and tilt, goes to next ball. Any ideas what the issue may on this thing?
Quoted from Troostr:I just unpacked my new to me Hook. It plays well until you hit the Skull hole, once it drops in there, it goes dark with “Slam Tilt” on the display. Game over ball kicks out to the drain and you can start over. Playing it a while longer, making sure not to hit that hole and somewhere in the upper play field it will get a skull and crossbones and tilt, goes to next ball. Any ideas what the issue may on this thing?
Sounds like you need to go over the switch matrix. I would suggest you start a game, remove the glass and trigger some switches manually; the under playfiel though (the skull lane) is in the same row as the slam tilt, switches in the same column might be stuck etc. Run a switch test aswel
Quoted from erikv:Sounds like you need to go over the switch matrix. I would suggest you start a game, remove the glass and trigger some switches manually; the under playfiel though (the skull lane) is in the same row as the slam tilt, switches in the same column might be stuck etc. Run a switch test aswel
welxome to the club! as erikv suggests sounds like you have a short either under the playfield or in the board in the backbox. if you can figure out what triggers the slam tilt in the upper playfield that would be helpful . do the switch test ( remove balls from trough) and manual trigger test as erikv suggests
here is the switch matrix to get you started
Good advice above, testing groups of switches and diagnostics is your friend here for possible short or faulty switch diode causing phantom activations.
Another thought, if new to you, was it working properly before being transported?
Quoted from astyy:Good advice above, testing groups of switches and diagnostics is your friend here for possible short or faulty switch diode causing phantom activations.
Yes it was, so I'm hopeful that its just a stuck switch somewhere.
Thanks for all the replies! I'll get a chance to mess with it today I hope.
This page was printed from https://pinside.com/pinball/forum/topic/hook-club-hook-is-back/page/39 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
