New! Dark mode!
(Topic ID: 86132)
Hook Club - Hook is back!
By winteriscoming
6 years ago
  • 2,050 posts
  • 180 Pinsiders participating
  • Latest reply 9 days ago by Asanteiro
  • Topic is favorited by 68 Pinsiders
There have been 618 images uploaded to this topic. (View topic image gallery).
There are 2050 posts in this topic. You are on page 37 of 41.
#1801 1 year ago
vbobrusev has the hook files to download here: http://vpuniverse.com/forums/topic/3656-data-east-hook-colorization/
He's also a member here and you may need to PM vbobrusev to get the pin2dmd files for a real hook as opposed to the vpin files.
#1802 1 year ago
I'm having the flippers die in multiball when lots of coils fire. It seems to come back shortly after, but is causing drains because the flipper doesn't fire when you go to catch the ball. Any tips? I'm not super familiar with DE games yet.
#1803 1 year ago
Quoted from garretswinning:
Im interested in purchasing pretty stoked its plug and play. How do i go about ordering one up for hook
Contact dpannell for the hardware.
#1804 1 year ago
Quoted from desertT1:
Ok, I think I have at least a short term fix for the flippers. I pulled and reseated the connectors on the flipper board and had a friend play several test games and over many multiballs did not have a single issue.
I am having one recurring issue that is REALLY pissing me off. The drop targets, when knocked down will increase the ramp value. Cool, I like that because it takes away the left ramp all day strategy that we got to use at Pinburgh. Well I have a drop that is frequently registering over and over while down with shock from the flippers or pops firing. I have fixed it twice already and last night it came up again.
The first time I fixed it was by cleaning the contact on the switch and adjusting it so it would press harder on the other side of the switch. The issue came back. So I replaced all of the switches with new ones. Problem went away. Then, after 2-3 weeks, it's back again. It's really annoying and because it will go away after I do stuff to the switch I don't think it's an issue elsewhere in the machine. Anyone else run into this?
#1805 1 year ago
I'm in the middle of shopping out a Hook, and I had a few questions for Hook owners.
Pic 1) For the treetop plastics, how does the top one attach? Standoffs? I found the top plastic in the bottom of the cabinet.
Pic 2) For the boulder plastic, where does that one belong? It was also found loose in the cabinet.
Pic 3) The Peter Pan plastic, I know where it should go, but not what the mounting hardware should be. Also is the left edge broken on my plastic?
Pic 4) Is there supposed to be something between the gap of the two clear plastic upright pieces? It had a bunch of electrical tape covering that space originally.
Pic 5) What is this little metal piece on the wood to the right of the launch ramp area? Is it supposed to be attached to something?
Pic 6 & 7) I have never seen wire wrapped around a post, like I found by the lower/center pop bumper. I'm assuming this was some wonky route hack... should those posts just have standard rubber rings on them?
Thanks for any help/pictures!
#1806 1 year ago
FYI this is what I started with: Just a bit of a protective dust layer to start with...
And where I'm currently at in tearing it down
#1807 1 year ago
Quoted from osver:
crash has submitted a very useful gallery of shop out photos here https://pinside.com/pinball/machine/hook/gallery
pic1) tree top plastic has standoffs, pics here
https://pinside.com/pinball/forum/topic/hook-club-hook-is-back/page/16#post-3544312
pic2) boulder plastic fits over bottom pop and a circular tree plastic, pics in a few of posts from here
https://pinside.com/pinball/forum/topic/hook-club-hook-is-back/page/18#post-3941266
I will check the rest on my machine later.
#1808 1 year ago
pic3) yes piece missing off your Pan plastic (common) that wraps around the vuk habitrail. The plastic screws onto the back of the windcoaster ramp. (ignore the plastic behind on mine which is a spare)
pic3) the gap is correct, dunno why taped perhaps ball hang ups, that's never happened on mine there
pic 5) dunno, that looks like where the skill shot ramp attaches, perhaps used as a spacer for some reason
pic 6 and 7) that spring (or similar) is actually correct and should be one fitted on each side of the lower pop, those areas are the only (on my machine) ball hang up on the game if not adjusted out properly
Interesting your machine has blue pop bodies a lot seem to be, mine are yellow.
Let me know if you need any more pics always happy to help bring a Hook back to life
#1809 1 year ago
Thanks a lot for those pics astyy
#1810 1 year ago
On my hook under the drop targets the wires where getting pinched from lowering the playfield it was kinda hard to see it. There was a repair bulletin about it but I can't find it
#1811 1 year ago
Quoted from Jerrybest:
Interesting. I'll have to see if that is something that is a factor on mine. I'll also try to find that service bulletin, but if anyone else finds it please share.
#1812 1 year ago
#1813 1 year ago
Thanks for sharing the information.
#1815 1 year ago
Quoted from Malenko:
Here is the new 128 x 16 pin2DMD display with built in controller for Hook, Batman, Star Trek 25th Anniversary, and TMNT. This is a bolt in color display replacement for Hook. All you need to do is transfer the display EPROM. Send me a PM if you'd like one. Here is a video of the new display connected to my DE checkpoint.
https://drive.google.com/open?id=1i_66gseXETjgTZmQHV2CCn6dKdxwSXlF
#1816 1 year ago
Is this pretty much a plug and play unit or will I need to get a color eprom?
#1817 1 year ago
Can't wait to see someone do a video with this display installed in their Hook!
#1818 1 year ago
You will need to remove the EPROM from your existing display and install it into the pin2DMD. At this point, it will work as a standard monochrome display. The game has been colorized by vbobrusev. As Malenko suggested, if you contact vbobrusev, he can provide you with 2 files that can be copied to your SD card for colorized gameplay.
#1819 1 year ago
Quoted from kciaccio:
@vbobrusev has alredy posted a video of his colorization of this game, see link below...
Quoted from vbobrusev:
Hook in color
#1820 1 year ago
I've colored TMNT and Checkpoint for "half sized dmds" ; TMNT was converted to a full sized DMD but if there was demand I could redo it for x16
#1821 1 year ago
Quoted from dpannell:
Thanks! Is there a site to buy this plug and play yet?
#1822 1 year ago
Quoted from pinballsp:
To buy the DMDMK66 and any product that I manufacture, you can contact me by private forum messaging, email pinballsp@gmail.con, Skype pinballsp, WhatsApp +34693344445, Facebook https://www.facebook.com/Pinballsp
DMDMK66 128x32, price 197 € + shipping costs (26€ for most of European countries).
Optional extras; preconfigured micro SD card + € 12, Amber filter + € 23.
You do not have to pay any kind of licenses with my products, the use of the Magic Editor is completely free and without limitations so you can use it to color any game, and the games that I color will also be free to download and use.
Regards
#1823 1 year ago
I think he means that can display the game in color
#1824 1 year ago
Ask dpannell
crash There is no working 128x16 DataEast Display from PinballSP afaik.
#1825 1 year ago
Correct, I misread. Sorry about that.
#1826 1 year ago
Hello everyone
i got too a hook pinball, after some work & clean , my pinball is now ready
so much fun for all the family
i just received a pinsound card and i am looking for a new mix package. Can someone share it one if possible ?
maybe i could work on it too and share it again after ?
thank a lot !
i have also some interrest with the color display. Is the operation complex ?
regards
#1827 1 year ago
I got to Bangarang for the first time last night. Best part was it was in a tournament and the player I had to beat to win the event had 96m after ball 3. I ended the game with 320-something million after starting ball 2 with 14m.
When I read about Bangarang somewhere I thought it was something to do with getting the 3-ball multiball, but that wasn't it. I decided to not read too much more about it after that. Funny thing is that the insert was blinking when it was ready and I've literally never noticed this insert before. I've been playing this game for 4 years, mostly when my former business partner owned the game. I've owned it for about a year now.
Got 45m in the mode by the way. I wasted some time tying to figure out exactly what I was supposed to do.
#1828 1 year ago
Just got my my new color display Pin2DMD installed today. Added two videos of it in action playing two horrible games lol..
Want to give a big thanks to pinsiders dpannell and vbobrusev for making it happen. Great people to work with.
Looks 10 times better in person...
#1829 1 year ago
Great job, that looks awesome! I appreciate the shout out but it's really Lucky1 who deserves the thanks, this is his creation.
3 weeks later
#1830 1 year ago
Hi
Hope some one can help me with my Hook pinball problem.
When i have played awaile, most often when multibal and i shoot for left ramp the sound dissapair til ball brain, or game reset, can happen in normal play to when alott happen.
Al boards are original, wath can be wrong?
#1831 1 year ago
Quoted from Run22:
Hi
Unplug the rope light on the wind coaster ramp and play the pin and see if the issue goes away.
#1832 1 year ago
I unpuged the rope light and ewerything work perfekt, no losing sound or resetting, Thx for the tip Hawkeye But What is wrong with the rope light? How Can i fix it?
#1833 1 year ago
Quoted from Run22:
Mine is doing the same thing. I'm converting my rope lights to LED lights and going to see if that's the issue
#1834 1 year ago
Maybe led wil work, lover voltage, keep me updated on the led convertion, if IT work i wil do the Same to my hook, Thx for helping me out
#1835 1 year ago
Your welcome. There is a power supply that controls the rope light. I would take a look at it and make sure yours is not defective. Its located top right of the backbox above the MPU board
#1836 1 year ago
Quoted from Run22:
Buy a new board for the rope light. I want to say its around 50 bucks. Mine had the same issue. Replaced that small auxiliary board and no problems in the past couple years
#1837 1 year ago
That chaser board (520-5054-01) is very simple with just a few components, may be obvious to inspect or test with your DMM and fix if that's your kind of thing in this hobby
#1838 1 year ago
First i wil try to change components on the chaser bord and then i hope it wil work without using to mutch power so soundboard fail, comming with update when the soldering is done
#1839 1 year ago
Quoted from Run22:
run22 your symptoms remind me of the thread below, where the rope pulls down the 12V supply to below the sound board threshold, the problem normally applies on 3rd party power boards (you mention original) but something else to read/check
https://pinside.com/pinball/forum/topic/bizarre-audio-break-up-problem-on-hook
#1840 1 year ago
Quoted from astyy:
I tried three different power boards and it had the same problem.
#1841 1 year ago
Quoted from astyy:
Building on what I said in that thread, anyone having this issue needs to investigate the +12v unregulated power rail with a meter. If this drops to 9v it will cause the amplifiers on the sound board to turn off until the voltage comes back up. Shooting the wind coaster ramp causes the rope lights to draw a high amount of current from the +12v supply. If this is happening, it is not the rope lights or the rope light aux driver board. That's only the symptom, the root cause is a weak +12v power supply. I would verify all connectors for that line are good and replace capacitors on your power supply, particularly C4 if using an original board.
In my case, I was using an X-Pin aftermarket power supply with a faulty +12v rail. I had to modify the board to include a larger filter cap which resolved the problem.
#1842 1 year ago
#1843 11 months ago
Could Someone post a photo of their flipper spring configurations? I'm currently rebuilding mine and looks like the flipper spring has been re-mounted across the lower light board....very sloppy... Please and thank you!
#1844 11 months ago
New power cap kitt arrived today, hope this vil solve the problem with sound/ ropelight,update wil come when i have time to solder the caps
#1845 11 months ago
OMG
Now the caps are change an Ewerything work But no sound? Wath is wrong, Have looked ower ewerything, cant se Notting wrong, need hjelp plz
#1846 11 months ago
when i looked ower the power board the owner before me had done alot cowboy soldring time to let go on this original power
New Xpin power board is on the way, hope this wil hjelp
#1847 11 months ago
Hopefully Brett has resolved issues with the regulated +12v power supply on X-Pin boards. If you test shooting the windcoaster ramp and the sound still cuts out, I would contact him with a multimeter voltage reading on the +12v supply while the rope lights are flashing. He’s very helpful.
#1848 11 months ago
THX for the info Crash
#1849 11 months ago
Got my xpin rev G to day, and just installed it, Wow! Ewerything is working so nice, rope light and sound dont Bug eanymore, problem fixed I think The bumpers hit harder than before? The Hole game seams smother/ fasther, I think Brett solved the 12v problem on rev G
The only negativ thing is little louder humming from speakers when stansing standby,
#1850 11 months ago
Quoted from Run22:
The only negativ thing is little louder humming from speakers when stansing standby,[quoted image]
Awesome! Have you checked out a pin sound board yet?
PinSound
$ 54.99
$ 48.00
