(Topic ID: 86132)
Hook Club - Hook is back!
By winteriscoming
5 years ago
  • 1,764 posts
  • 157 Pinsiders participating
  • Latest reply 8 days ago by pinballsp
  • Topic is favorited by 57 Pinsiders
There have been 494 images uploaded to this topic. (View topic image gallery).
There are 1764 posts in this topic. You are on page 18 of 36.
#851 1 year ago
Quoted from futurepinhead:
I guess it could be the resetting issue. I never thought of it that way. The score remaining correct and the ball count changing threw me off, but I supposed that could be it.
Where did you buy your DE ribbon cables? I'll buy some today.
Great Plains Electronics has them cheaper but I think you need to have the length and pin count.
#852 1 year ago
Wow, I wish I would have thought at looking at Great Plains Electronics first, they are a fraction of the cost of Marcos. For future reference if anyone is reading this, the Ribbon cables are 20 pin and 26 pin connectors. Not sure on length without measuring the old ones.
#853 1 year ago
Here is a video of it after installing new Ribbons. I don't this is a code bug any longer.
So new power supply rebuilt, New ribbon cables. What should I look at next?
#854 1 year ago
I would replace the connector and header on the display driver board for the 5v power supply. But before doing that, I would verify you are getting a stable 5v (or close to 5v) to the connector. You can press your meter leads against the pins in the IDC connector from the back to check this. I would do this with the display unplugged as from experience a poor connection at the board can cause this to read low and make it appear to be an issue between the power supply and the connector.
#855 1 year ago
I just tested the 5v at the DMD power connection. 5V was unwavering. Even when in multiball. When I plugged the connection into the DMD, it went down to 4.9v. I did not test that during gameplay.
#856 1 year ago
Then your DMD may have issues. You can try reflashing the display ROM if you have an EPROM burner.
#857 1 year ago
Quoted from Crash:
It was actually resetting before the new roms, but I never noticed the Ball 1 before which made me assume it was the new code. I have a TMNT and I'll swap the displays tomorrow and test. The connector tested fine the whole time so that leads me to believe it is the male end (solder looked okay, but I can always reflow) or it could be something else on the DMD.
#858 1 year ago
Any luck with swapping the displays futurepinhead ? I've pretty much resigned myself to the problem being on the DMD itself and I'm waiting for pinballsp to release his 128x16 Colour DMD.
Another symptom is that if you play multiplayer then after the DMD crashes it resets each players score to 0 and only shows the players up to the current player. It all returns to normal when the next ball starts but does spoil a multiplayer game.
#859 1 year ago
Quoted from astyy:
I've not had a chance to swap them yet, but I have set aside time to swap them Wed night so I'll check back in then
#860 1 year ago
Ok so I swapped DMDs with Hook and TMNT and now both work. I don't know if TMNT is less demanding or if it's the Rottendog PS that's installed in TMNT. Either way I believe it was the DMD and for the time being, both appear to be going fine. I'll update you if that changes
#861 1 year ago
Thanks for reporting back and good result. I wonder if re-seating whilst swapping the display ROMs over made a difference too. Certainly on mine the new ROM when I upgraded to Hook 5 improved things. I'm waiting for PinballSPs Colour DMD to try next.
#862 1 year ago
Quoted from astyy:
Can you send a link? I haven't heard of that.
#863 1 year ago
Quoted from paynemic:
Pinballsp has posted information and a photo of the board design for 128x16 here;
http://www.pinballinfo.com/community/threads/dmd-led-color-dmdst32-manufactured-by-pinballsp.33923/page-10#post-197840
1 month later
#864 1 year ago
Need some help
Was playing my hook machine and out of no where while playing the game reseted itself. Now when i press start i get two hook announcements and thats it just keeps reapeating hook twice. Has anyone had this problem or know where i should start. Im also running hook 5.0
Thanks for your time and support
#866 1 year ago
Check your 5v supply from the power supply board. CPU and sound board are resetting.
#867 1 year ago
Quoted from Crash:
Ok thanks. Ill check it tomorrow and post on what i find
3 weeks later
#868 1 year ago
Checked the 5v connectors and multipule other connectors. All with correct voltage. So i cycled the machine and everytime it started i would lose the 5v on my meter and the PIA light on the cpu board would turn on.
#869 1 year ago
Can anyone help me with what is under the boulder plastic on the bottom pop? I've just finished restoring my hook and I'm missing this plastic. It looks from pictures to have some rivets in it. Thanks for any help. Oh and here's my hook. Before and after.
#870 1 year ago
Quoted from Boof-Ed:
Which one you want? ebay.com link » Data East Hook Pinball Machine Full Playfield Plastic Set Also Sell Separately
#871 1 year ago
It's the circular tree one shown in the Ebay link above.
Nice work on your cabinet, is it painted or decaled?
#872 1 year ago
Sorry guys. I meant what is riveted on to the boulder plastic. I have the tree ring. I have a plastic coming but nothing on it. There seems to be rivets on all pictures I've seen of it.
The cabinet is decaled. Was a lot of work to get it up to a standard to decal. Split corners, delaminating all over the place. Lots of glue clamps and resin but came up a treat.
This is the best picture I can find of it. Is it a ball deflector or something maybe.
#873 1 year ago
Gotcha, yes a small deflector, here's some pics to help. In the 2nd pic make sure you have that pin as that can be a ball hang spot.
#874 1 year ago
Hey guys, a couple of game play questions... I have played loads of games on my machine now and I have never ever had an extra ball or special from the pirate ship targets, it's only ever 10 million. Also no idea what lights them for 10 million! Additionally there's the extra ball insert pointing at the skull, never had this either. Can anyone confirm what/how this is meant to work? I am running Chad's (excellent) code update. Thanks!
#875 1 year ago
Quoted from ChriX:
I don't recall specifics around Pirate Award choices and how they are determined... but I can tell you that the Pirate Award is only ever offered up on Ball 3. It is activated after hitting a random number of switches between 8 and 80. (If in Tournament mode, it is activated on the same number of switches every time... which if I recall correctly is 80.)
Also, if you are on Ball 3 and get an extra ball, thus playing Ball 3 again, I think Pirate Award will be offered up again.
Actually, I should say that it is offered on the "last ball"... so for example, if your game is set to 5 Balls, then it will only ever be offered on Ball 5.
#876 1 year ago
Speaking of Tournament Mode (newly added in v.5.00 update)... I am curious to know if anyone uses this?
Have you played the 5.00 update in Tournament Mode and in an actual tournament? If so, how did it go?
#877 1 year ago
I have recently got my hook boards serviced and now just really started playing chads code in more depth.
I am really really enjoying it. I have just set it to tournament mode and will check it out.
#878 1 year ago
That is incredible! Can you give me a quick rundown on your process?
#879 1 year ago
Quoted from Chalkey:
Hard to do a quick rundown. It was a big process. I'll send a pm and here's some pictures. There was a big void under the top ply veneer. I drilled holes and used a syringe to fill with resin.
#880 1 year ago
Wow. Great job
#881 1 year ago
What type of green liquid you using in injector?
#882 1 year ago
Quoted from ChriX:
I'll pay more attention, but I'm sure I've had all 3 Pirate Town specials - perhaps the extra ball offered relates to whether you were offered it on the skill shot ramp first, which only seems to happen on the last ball of a low score game (often!). What happens on mine is that sometimes Pirate Town isn't awarded but that could be a flaky drop target switch.
The extra ball insert pointing to the skull I've only ever seen lit once or twice in the years I've owned Hook and that's since Chads (excellent) V5 update.
What's also rare is being offered the "free" multiball on skillshot hole 1. Have only seen that a couple of times on last ball.
My favourite Hook shot is recovering a 2 ball multiball to 3 where you lock a ball in the VUK, then shoot the windcoaster and have the first ball returned via the (underused) diverter.
Ha, it's nearly the weekend let's play some Hook.
#883 1 year ago
Quoted from vbobrusev:
Fibreglass resin. Seeps right into all the loose ply and is as hard as nails once set.
#884 1 year ago
Well i found the problem with the restart with alot of help from todd at tnt amusements. its the board that runs the rope light on the wincoaster.
#885 1 year ago
Glad I could help! It had to be one of the three things I told you!
#886 1 year ago
Quoted from garretswinning:
Are you using an aftermarket power supply? If so check the solution in this thread.
https://pinside.com/pinball/forum/topic/bizarre-audio-break-up-problem-on-hook
#887 1 year ago
Has anyone came out with a color did for hook yet and I'm not talking about just a single color. I think someone was working on one but forgot where I had read it
#888 1 year ago
PinballSP is working on this, but it's not done yet.
#889 1 year ago
Anyone know where and if someone makes a shaker for hook i think it would be a great touch any thoughts?
#890 1 year ago
Excited to be part of the club! Picked it up with one broken plastic (already have a replacement ordered) and some lights out. Just general cleaning needed otherwise. Anyone know where to get a repro clear red shooter rod?
#891 1 year ago
Wow is that backbox colour LEDs?
Quoted from ChrisRAD:
I got mine from a UK supplier but looks much like this one on Marcos - http://www.marcospecialties.com/pinball-parts/20-9253-9
Originally there were DE logo ones but they seem to mysteriously dissappear
#892 1 year ago
Where did you find a single replacement plastic? This game and a lot of other Data East games use partially transparent plastics. I know CPR has been doing Data East sets in the past year but like you I occasionally have only one or two that need replacement.
#893 1 year ago
Quoted from Crash:
I have extra plastics from when I first got my machine I bought every one I could find even if I didn't need it. Pinball life carries the clear red shooter rod
#895 1 year ago
I see Pin2DMD are making progress on 128x16 support too;
https://pinside.com/pinball/forum/topic/stolen-pin2dmd-color-rgb-controller-from-pinballspcom/page/16#post-3987854
Ummm, the title in the URL is different to the thread
What are the pro's and cons of the two options?
#896 1 year ago
Quoted from astyy:
Most of the features PIN2DMD already has implemented in the last 2 years, like frame by frame colorization are currently only announced for PinballSP´s MK66. He is a very good and fast hardware designer but software programming and bug fixing is the more complex and time consuming task. So far there has been no video of PinballSPs 128x16 board working. Because from our side PIN2DMD is still DIY project we will release the DIY version of the DE 128x16 controller as the next step but a plug and play custom hardware is also already planned by some hardware suppliers.
So from the functional side there are more pros for PIN2DMD. The "cons" for PIN2DMD are that the software is non commercial and it needs a 10$ donation for the activation key. We forward those donations to charity organizations like orphans home. The currently available hardware is also not as much plug and play as PinballSPs but the hardware suppliers are working on this.
#897 1 year ago
#898 1 year ago
Added a cheap light that’s used for inside pumpkins on Halloween haha. Cool since it lights up the walls behind the game also.
#899 1 year ago
If all goes well I'll be in the club by the end of the day. Only problem is the owner doesn't have keys so it's going to be a bit of a leap of faith if there are any problems, and moving it if I have to use the dolly. Who knows what might be in the coin box that might come crashing down. My Jurassic park captures the balls that are in the trough even when the playfield is lifted, is hook the same?
#900 1 year ago
So I just realised that the yellow dome next to the right ramp on top of it dissent even have a socket for a light there. Can anyone post a picture of what it is tied into so I can wire it it.
Guy above this post. Take a drill and drill out the center of the lock and you can open it. Def check inside before buying
$ 9.99
2,300 (OBO)
Orange Park, FL
Metal-Mods
Metal-Mods
4,000 (OBO)
Brownsburg, IN
$ 399.95
$ 26.00
Yorktown Parts and Equip
Ballston Spa, NY
Sparky Pinball
Sparky Pinball
3,700 (OBO)
St. Louis, MO
$ 299.00
$ 16.00
$ 26.50
$ 40.00
Professor Pinball
