(Topic ID: 299252)
Homebrew TreeHouse Club
By stefanmader
1 year ago
There are 242 posts in this topic. You are on page 2 of 5.
#51 1 year ago
Made a lot of cables today, but i have some error on the pc, so no flipping today.
And you might notice, i put the cobrapin on the playfield now. Thats way better than having all cables go from the playfield to a second board with the electronics. Didn't think of that before.
#52 1 year ago
PC Problem is solved, TreeHouse Club is flippin'
#53 1 year ago
wow, nice project again, you're going like a runaway train
#54 1 year ago
Quoted from MeesterPieter:
Thank you very much
#56 1 year ago
Those slings are crazy strong. Reminds me of my nephew running around the backyard after a couple doughnuts.
#57 1 year ago
Quoted from TreyBo69:
Haha, yeah already took the power down a little. I started with the values i have on my other homebrews. Funny that it is so different here.
#58 1 year ago
Mounted the switch and up downpost for the lower playfield and did some basic code that shuts of the flippers while the ball is on the lower playfield. And the lower slingshots are actually fun as i hoped
IMG_20210929_205300.jpgIMG_20210929_205306.jpgIMG_20210929_210911.jpgIMG_20210929_210915.jpgIMG_20210930_141927.jpgIMG_20210930_141934.jpg
#59 1 year ago
Ramp mark ups, and upper playfield testpiece.
And kickouthole ramp
IMG_20211003_110712.jpgIMG_20211003_110718.jpgIMG_20211003_110727.jpgIMG_20211003_110745.jpg
#60 1 year ago
Installed some christmas lights, they are really bright. For some places where i can't fit those big lights i will solder some neopixel from a strip.
IMG_20211004_144703.jpgIMG_20211006_192506_1.jpgIMG_20211006_192518.jpgIMG_20211006_192530.jpg
#63 1 year ago
thank you, with the lights in now, i can start coding some stuff .
#64 1 year ago
i do really like the way you fit it into an arcade cabinet,when you're bored you might wanna steal some idea's from "the pinball circus"
#65 1 year ago
, i had circus on my mind, when i first thought about this project. It is such a unique machine, love it. There is another one that has an arcade cabinet. and plays vertically (with mirrors), called "Varkon". also a really cool and unique machine.
#66 1 year ago
Hm not having a good day. Wanted to do some cabinet work and pulled out the playfield and forgot to disconnect the usb c cables. Ripped the usb c connectors off.
#67 1 year ago
That’s a good illustration of the beauty of your platform. Those Microcontroller modules are inexpensive to replace
#68 1 year ago
Quoted from Cmartin1235:
Yes that is true! I have ordered another cobrapin and thomas will ship me two blue boards as well. So the damage is minimal. Just the stupid feeling that this could have been easily avoided stays.
#69 1 year ago
Quoted from stefanmader:
I know that feel very well. Got lucky on my last build - blew the solenoid fuse while the game was on and barely avoided frying the controller for switches in the process.
#70 1 year ago
I have fried a p3roc once. Don't really know what i did wrong, but redid a couple of things and checked everything 5 times and it worked out the next time. Frustrating but that's how you learn a lot
#71 1 year ago
If u homebrew I think it’s a rite of passage to fry at least one controller board. I fried my fast nano board a while back with a stray pinball that fell and connected 5 and 12v on the board on the way down. Good learning experience
#72 1 year ago
Quoted from Mbecker:
Oh wow that sound horrible. I also hat balls fall down in the cabinet. Fortunately nothing broke, but that was a very scary moment...
#73 1 year ago
nice to show the fails as well, such a very relatable mistake
#74 1 year ago
And more to come for sure
#75 1 year ago
Made some cabinet work. Mounted the monitor and a back door. And tried out something new for wire ramps. I don't have a welder, and i'm having a hard time with welding and soldering the ramps. So this time i thought i try this special glue out. I love it, it is a really strong bond,much stronger than my soldering the last time. Also mounted the sub woofer.
and made an apron plate.
its not the time to make the cabinet pretty yet, but i am thinking i will put some foam on the side and carve it a bit to make it look like tree bark.
IMG_20211011_215529.jpgIMG_20211011_220034.jpgIMG_20211017_100426.jpgIMG_20211017_100430.jpgIMG_20211028_150957.jpgIMG_20211028_151015.jpg
#76 1 year ago
Nice, doesnt the copper bend to easy?
#77 1 year ago
We’re you soldering or brazing? If you go with.. I think it’s bronze wire.. brazing is a great option with a blow torch and brazing rods. Pretty dang strong. Looks like that glue will work good tho
#78 1 year ago
It bends easy yes, but it is totally strong enough. With 4mm thickness.
#79 1 year ago
I was trying it with a blowtorch and soldering wire. I have mixed feelings about this, sometimes it worked really well, oder times with the same technique, no success.. Also i might have soldering wire that is not the perfect material for that.
So the glue worked well when it has much touching surface. But when i glued an additional rod 90 degrees to the ramp so that i can screw it to the playfield it didn t work that great...
#80 1 year ago
So i have made a 3d printed version now. I think it looks way better. I might try metal rods again with 3d printed parts to hold them in place. I seems to work good for sonic spinball.
Also im not sure if you can see the inlane inserts when there is a big 3d printed part there.
#81 1 year ago
Let's see, if i change that later, but for now i am not going with the wire ramps.
#82 1 year ago
if you switch out your standups for rollover droptargets you can also use the space in the top left corner for something else
#83 1 year ago
I'm not sure i can fit the drop targets, i will need some space for one single droptarget in the left space. I plan to make a platform there for the monster excavator which will be an enemy. I will try to use a smart drop target to raise the the bucket to reveil the monster head. It will be a tight fit with the drop target bank and my subway.
#84 1 year ago
I might buy a 4bank and try it out. 3 for the excavator and one for the goose. I could put a rubberband behind it and just reset it at every hit.because of the goose it wouldn t make sense to reset it when all 4 are hit.
#85 1 year ago
Ah yea— sometimes I had similar issues but usually seemed to be due to both pieces of metal not being hot enough. It’s a bit finicky for sure.
#86 1 year ago
Maybe there is a sweetspot, how hot it should be.. Hm well anyway not my favourite thing to do. Maybe i just have to get into vacuum forming, and that will solve all my problems
#87 1 year ago
could be nice to make another hole behind the targets that goes into your subway
#88 1 year ago
that's not a bad idea, i'll keep that in mind when the drop targets arrive. just orderd a 4bank
#89 1 year ago
Was at the fantastic pinball and jukebox museum Terra Technica and saw not just one but two vertical pinball machines.
#90 1 year ago
interesting for sure
#91 1 year ago
This project is looking great so far, I'm a big fan of anything outside of standard game dimensions!
It's interesting you bring up the shaker ball games and Varkon. I got to play a Varkon for the first time recently, and I was surprised how good it was. The vertical effect was a lot more effective than I would have thought, and changed how I experienced the game significantly. I've been thinking about making a mirror/"vertical" game myself since, there's a lot of design space in that format I think.
#92 1 year ago
thank you,
i would love to play varkon. maybe someday..
making such a game sure would be fun. those machines that i saw, it was very hard to get a feeling how long the playfield is, very hard to see inside.
i guess that would create a limit of what is possible with such a machine, you'll nee a certain angle and then the machine shouldn't be too wide.
and varkon has solved that with its gameplay in a really cool way.
would love to see you make such a project
#93 1 year ago
Made some things for the powerswitch and sound system. Will make 3d printed speakercovers and a panel for volumecontrol. Also the pc powerswitch is still in the mail.
And successfully put the drop targets in instead of the standups. Tight fit, but it works. Didn't have time to connect all the cables yet. And i have a hard problem with the subway to the lower playfield. The ball will just drop straight down the middle. Thats a hard one to solve.
IMG_20211117_095451.jpgIMG_20211117_095558.jpgIMG_20211117_134429.jpgIMG_20211117_134601.jpg
#94 1 year ago
fits very snuggly
#95 1 year ago
Oh yeah hihi. I am very happy about the drop targets , it is just so much cooler with the extra action happening in the playfield.
#96 1 year ago
I'm working on lot of projects at the moment, but still now and the a little bit of time for progress.
#97 1 year ago
thats the way to go, also gives you more time for inspiration
starting to look good
#98 1 year ago
Love the cabinet. Nice work.
#100 1 year ago
Bigger upper playfield. There will be a centerramp at the normal playfield that feeds a vuk which shoots the ball up to the big upper playfield. I will try to put some rubberposts there to stop the ball and make it roll to the flipper slowly.
I am thinking that the donkey kong like shooting barrels won't be barrels anymore. I think it would be more fitting when a treehouse roof hides the coil.
Men
Displays
FlyLand Designs
Displays
$ 18.95
This page was printed from https://pinside.com/pinball/forum/topic/homebrew-treehouse-club/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
