(Topic ID: 161273)
Home Version Pinball Machines
By Aladdin
7 years ago
  • 18 posts
  • 6 Pinsiders participating
  • Latest reply 3 years ago by Aladdin
#1 7 years ago
I don't see a thread dedicated to Home Version Pins so I thought I'd start one. This thread should be about any Home Version Pinballs. Mods, Tech Help, WTB, For Sale, Questions, Etc. Pins like, Fireball Home Version, Galaxy Ranger, etc
I just picked up a Home version edition of Captain Fantastic. It's in beautiful condition. The bad is that the game won't boot. I think it's the CPU Chip, but I don't want to spend $$$ getting the replacement chip if that's not the problem. It's a Series II.
So I need advice.
Here's the bad:
The game won't boot and the display is blank.
Here's the good and what I've looked at:
The flippers flip (found out that they are energized all the time)
The GI lights come on and the flashing pop bumper lights do to
The Circuit Breakers seem ok and not open
I've pulled the power supply and gave it a good look over for bad solder, burnt connectors, etc
I've re-seated the CPU Chip and all connectors
Tested the voltage on the main board and both check out 5.9 VDC and 5.09 5+
Thoughts, suggestions? Do I just pull the trigger and get the CPU Chip?
3f42158aec62ef1651d91f592431d5c32d053cc0_(resized).jpeg3f42158aec62ef1651d91f592431d5c32d053cc0_(resized).jpeg
39e8ee082c6827d268aae138e9fc6ed460d11c2f_(resized).jpeg39e8ee082c6827d268aae138e9fc6ed460d11c2f_(resized).jpeg
b01ae9464a5808eb5a1cffb287d3399758651eab_(resized).jpegb01ae9464a5808eb5a1cffb287d3399758651eab_(resized).jpeg
#2 7 years ago
Can you post good, clear photos of the MPU and power supply?
Just because a board won't boot doesn't mean the issue is the CPU chip.
Has the battery leaked?
Is the power supply giving all the expected volrages, and is the MPU receiving them?
Any burnt connectors?
Does the reset signal get sent to the CPU? If you short the appropriate pins to fake a reset signal, is there any change?
Any issues with the ROM chips or sockets?
http://www.pinwiki.com/wiki/index.php?title=Bally_Home_Models
Diagnosing a home model game is like working on any other game. It's just that the parts and boardsets are different.
#3 7 years ago
Thanks for the video! I need to check the Start Button circuit since the Start Button seems to activate the display and computer. There are no batteries on the Home Version that I know of.
#4 7 years ago
Quoted from Aladdin:
So I need advice.
Here's the bad:
To funny, I have that exact same pf, complete on the back side too. It's just beautiful with just a little bit of cupping of the inserts. No wear or faded colors, plastics perfect no yellowing or chips, all metal perfect no rust. Don't know if it works but it sure is pretty.
#5 7 years ago
I couldn't believe how clean it was when I lifted the PF. No spare parts, dust, wire snips, black tape, dead mice, etc. It looks new. I'm actually surprised at the level of quality that went into this.
#6 7 years ago
Shorted the Start Button (bypassed the switch) nothing
#7 7 years ago
Still messing around with connectors. The display flickered with 1000 then went out- it's not supposed to light up unless you press the start button.
I checked the voltages again at the capacitors on the board and got different voltages
6.1 for VDC and 1.78 for 5+.
Then I reseated the connectors on the head and back it went to 6.3 VDC and 5 on 5+
Still no boot
#8 7 years ago
Here's the capacitors where I check voltage and the display when it flickered
#9 7 years ago
I'm thinking to reflow the solder on all connectors?
#10 7 years ago
Her's some photos of the boards. The resistor on the power supply looks a little crispy.
The prior owner did replace a transistor
#11 7 years ago
I remember seeing these new @Montgomery Wards circa 77-78. Good luck.......
#12 7 years ago
Is that one transistor dark, second one bottom right?
#13 7 years ago
That's a shadow, but that is the one that was replaced.
Different style of transistor. I need to look at a schematic now
#14 7 years ago
Quoted from ForceFlow:
I need to learn how to do this---
5 months later
#15 7 years ago
Got it to work!!!!
Rebuilt the Bally Power Supply Series II. I only changed out the Resistor and two power regulator transistors on the heat sink. Then I plugged her back in to check (don't fix it if it ain't broke) I haven't replaced the diodes or caps yet.
I bought a Hakko 888D to force myself to get better at board work. MY GOD where have I been? I've been using a 25W iron all my life and wonder why soldering is such a pita.
Special shout out to KenLayton for posting his "how to". stevekulpa for posting photos of the PS on his repair website.
Also to those who are here to help others on Pinside like ForceFlow
Thank you!
5 months later
#16 6 years ago
I'm trying to repair on of these for a friend. I've got most of it running well except for a couple segments on one digit. Does anyone have an extra display or perhaps a dead series II board I could buy to get the display from?
Robert
2 years later
#17 3 years ago
Yes this is an old post however it fits my machine. Fireball he pops the GI circuit breaker. Bulbs are all good. Any ideas?
1 month later
#18 3 years ago
Quoted from snextime:
I wouldn't worry about old posts if they are the same topic. Just seeing this. Did you figure it out? If the circuit breaker is popping, you might have a transistor issue like mine did in it's past.
Other
The Pinball Scientist
Protection
$ 44.99
Pinball Shark
Shooter rods
$ 12,000.00
Classic Game Rooms
$ 52.99
Pinball Shark
Shooter rods
$ 5.95
Protection
$ 15,000.00
Classic Game Rooms
$ 69.00
$ 22.50
Magazines/books
Pinball Magazine
Magazines/books
Protection
This page was printed from https://pinside.com/pinball/forum/topic/home-version-pinball-machines and we tried optimising it for printing. Some page elements may have been deliberately hidden.
