(Topic ID: 73213)
Home for the Gottlieb SYS1-SYS80B guys, Yep it's a club :)
By Gerry
10 years ago
  • 6,686 posts
  • 662 Pinsiders participating
  • Latest reply 2 days ago by RDBowers
  • Topic is favorited by 330 Pinsiders
There are 6,686 posts in this topic. You are on page 134 of 134.
#6651 35 days ago
Quoted from Billc479:
Does this issue indicate the 5101 is bad
Sure sounds like it. I make a NVRAM that replaces the 5101 on System 1 boards. If interested, let me know.
#6652 27 days ago
Two follow ups on my System 1 issues:
Changing the 5101 did not fix my memory issue. I used the same part number, it was a chip I pulled from a working board. To save you from searching, it does not hold scoring levels or HSD. It only allows one game at a time. Each game ends as is the machine thinks that’s a new hi score, and the machine sounds like it awards three credits, but only shows one in the credit window. Using it drops the number to zero when starting a game, then one after the HSD award.
Using the SMD chip I mentioned did not work. The machine only displayed players 2 & 4, and nothing in the credit window or ball in play display. When I get a chance, I’ll see if I can figure out why it didn’t work.
#6653 26 days ago
I had some issues on my System 80 after installing NVRAM. Turned out that I needed to go through the self-test and clear out various pieces of garbage data and set the various scoring thresholds. Not sure if System 1 is the same.
#6654 26 days ago
Quoted from sparky672:
Yes, sys1 is the same, need to clear everything.
#6655 26 days ago
I’ll try clearing again and report back.
#6656 26 days ago
I hit the reset switch at every step, 1-10, rolled back thru to set award levels and HSD, nothing sticks.
Each game played is awarded as if it was the HSD. The award levels do not award anything. The credits still only say one, even though it sounds like three are awarded.
I’m at a loss. Any ideas?
#6657 23 days ago
I've owned my Sinbad for a close to 1.5 years now. I modded the original MPU to use a CR2032 with the blocking diode. I have tons of CR2032 that I bought a few years ago. Generic ones. So, anyway, I used one of those back when I originally did the work on the game. That lasted about a month and died. I changed it to a brand new Energizer CR2032. I only got a year and change out of that one and had to change it the other day. So, just wondering if System 1s eat batteries that fast for others or if something might be going on that's killing the battery. Game plays fine and holds data after the new battery and going through the options and clearing all the ram.
#6658 23 days ago
Quoted from RC_like_the_cola:
Can't answer specifically, but some brand of of 5101 RAM chips consume more than others in sleep mode.
Also the chips at Z1 and Z2 are powered by the battery so they're consuming battery power. Might be worth installing a larger coin battery.
https://pinside.com/pinball/forum/topic/wpc-cr2032-mpu-install/page/2#post-8047167
#6659 23 days ago
Quoted from Quench:
Thanks for the info, as always. I don't mind changing it more often, if needed. Just wanted to be sure there wasn't something wrong. Those Z chips draining power wasn't something I was aware of. If I need to pull the board in the future, I'll consider swapping a larger cell in there.
#6660 23 days ago
The 2032 battery I swapped into my Black Hole Sys 80 over three years ago is still working fine. I am very surprised, given the size of the battery and it's such an early system. I figured I'd get a year maybe no matter how great the battery was, if I'm lucky. The battery is just a cheap Chinese brand that neither I nor anyone else has ever heard of. Don't know if there's a significant diff between sys1 and sys80 as far as memory current draw goes though.
#6661 23 days ago
Quoted from frenchmarky:
That is interesting. On a Sys1 the battery powers Z1 and Z2, on Sys80 only Z1. I wonder if they improved the circuit on Sys80 to avoid excessive drain.
You (I) learn something new everyday I guess
#6662 23 days ago
Quoted from Cheddar:
On system 80, it's Z1 and Z4 as well as the 5101 RAM at Z5.
As I said, some brands of 5101 RAM chips draw more power than others.
#6663 21 days ago
Regarding the Sys80 mod where you should add the extra (parallel) 5v and ground wires to the interconnect connectors -
The boards were otherwise designed and built to use the two extra connections for reliability (can't think of another reason anyway), and the schematics show both of them there. So of a-a-all the wires in the whole friggin' game, Gottlieb leaves *THESE* two out? WHY? Was it a factory goof from the start? Especially after Sys1's previous history of grounding problems, and its connector only had single board pins for gnd and 5v.
Were ALL sys80s absent these two wires?
#6664 21 days ago
The boards were otherwise designed and built to use the two extra connections for reliability (can't think of another reason anyway), and the schematics show both of them there. So of a-a-all the wires in the whole friggin' game, Gottlieb leaves *THESE* two out? WHY? Was it a factory goof from the start? Especially after Sys1's previous history of grounding problems, and its connector only had single wires for gnd and 5v.
I believe it was fixed late in the Sys80 lifespan. In one of toddtuckey videos, he mentions when they finally fixed it and started including those wires from the factory. I can't recall the game or if it was a 80A or 80B game. Perhaps he can chime in.
#6665 19 days ago
Pinwiki didn't seem to nail it down more, it just describes the mod and it's filed under 'Sys80/A/B'.
#6666 19 days ago
I have a Dragon pin. Boots up fine. When you play 1 player both 1 and 2 player display the score from player 1. What should I look at.
#6667 9 days ago
My Incredible Hulk is in very good condition (playfield). With the exception of the cupped inserts. Going to go through and change them all out. Does anyone know of a source of insert decals?
#6668 7 days ago
Is there an online or pdf version of the Gottlieb 1992 Parts Manual available?
#6669 7 days ago
Quoted from Rampmaster:
Leveling the PF and filling with clear can give pretty good results... or even just filling the cupping with clear to sand down flat and keep the original lettering?
#6670 7 days ago
Quoted from RonSwanson:
I could never find it. I ended up buying one on eBay.
#6671 7 days ago
I bought some of the parts manuals from pbresource.com
#6672 7 days ago
I do have a PDF. It is a pretty large file with 87MB. I can send it by wetransfer if desired.
#6673 4 days ago
Anyone have a complete list of all the connectors in the backbox for Sys 80b? I want to redo all the connectors in my Genesis. I figure I can save myself some time opening my backbox and counting if someone knows where this information can be obtained.
#6674 4 days ago
Quoted from Menthelm:
This should do the trick. I have complied this from several sources in an effort to produce all the single side connectors.
#6675 4 days ago
Quoted from RDBowers:
Awesome! I appreciate it. I've been meaning to re-pin all the connectors since I bought the machine. Think I've had it almost 5 years now lol
#6676 3 days ago
Not directly, but I do have a copy of the pdf file.
Several other catalogs too...
Just send me a pm with your request.
Peter
http://www.inkochnito.nl
#6677 3 days ago
You should be able to reuse the housings unless they are burnt up. Just replace the pins.
#6678 3 days ago
Thanks to all who replied. I received a copy of the parts catalog. Now, to find an actual decal or scan of this one for Gold Wings (part 25169). Unfortunately, Pinball Resource is out of stock.
Screenshot 2024-07-13 121844 (resized).pngScreenshot 2024-07-13 121844 (resized).png
#6679 3 days ago
wroung posting...
#6680 3 days ago
Quoted from chuckwurt:
I'm wanting to replace the old style connectors with the ones that have the crimp on terminals.
#6681 3 days ago
When I did my Panthera, the IDC connectors doubled as molex as well. Simply cut the old wire off, pull the excess from the connector, repin, insert the water back in just like a molex connector.
#6682 3 days ago
If you need new connectors, I produce the single side edge connector kits. Each kit includes the housing, pins and labels. They are sold through Marco in the US and PinballLEDs.ca in Canada.
#6683 2 days ago
Good work!
Correct me if I am wrong... regarding your position nomenclature, "right-top", etc; I thought that not every game has all boards mounted the same. How to define "right" when the boards are mounted sideways? How to define "sideways" when you don't know the most common mounting orientation?
Example:
#6684 2 days ago
Good work!
Example:
I'm pretty sure the board itself is marked. Will be printed on there by where they plug in.... J1, J2... ect.
#6685 2 days ago
I know the boards are marked with the connector numbers. I am merely questioning the purpose / accuracy of including positioning information like "right-top", etc. when the board may be mounted in such a way that it's really "bottom-right".
#6686 2 days ago
Good work!
Example:
I agree. When installed the orientation could be anyway. I created the list for my use. I would be looking at the board when it is out of the machine. Writing on the board would help resolve what is top/right/bottom/left. Also images in the catalogs help with the orientation. So top is top, right is right, bottom is bottom and left is left.
Screenshot 2024-07-15 155832 (resized).pngScreenshot 2024-07-15 155832 (resized).png
Screenshot 2024-07-15 160103 (resized).pngScreenshot 2024-07-15 160103 (resized).png
3,495
6,700 (OBO)
Gilbert, AZ
2,800
Grand Rapids, MI
$ 1.00
Pinball Alley
Toast-Mach1 Mods Shop
$ 1,159.00
$ 1,159.00
$ 8.00
Cobra Amusements
$ 1.00
Pinball Alley
$ 259.99
$ 1.00
Pinball Alley
$ 99.00
RGP Models
$ 1,059.00
$ 49.99
$ 50.00
Duke Pinball
$ 1.00
Pinball Alley
1,940 (OBO)
Reno, NV
$ 7.50
$ 6.00
Twisted Tokens
