(Topic ID: 73213)
Home for the Gottlieb SYS1-SYS80B guys, Yep it's a club :)
By Gerry
10 years ago
  • 6,543 posts
  • 651 Pinsiders participating
  • Latest reply 4 days ago by Sammer
  • Topic is favorited by 324 Pinsiders
There are 6,543 posts in this topic. You are on page 122 of 131.
#6051 1 year ago
Quoted from Tokkentakker:
I might try a Swemmer board I have but I would have to jumper it differently. Where can I learn more about your product?
I will be setting up a website for the Gottlieb diode clamping boards and some boards for other pins and prototype boards. In the meantime you can read about them in this post:
https://pinside.com/pinball/forum/topic/home-for-the-gottlieb-sys1-sys-80b-guys-yep-i-guess-it-a-club/page/103#post-6750517
This one shows how I install a memory cap on these boards.
https://pinside.com/pinball/forum/topic/home-for-the-gottlieb-sys1-sys-80b-guys-yep-i-guess-it-a-club/page/111#post-7069741
Works with original Gottlieb boards and the Swemmer boards. The Swemmer board is easy since it has socketed ICs and just plugs in. Gottlieb boards may need sockets installed.
#6052 1 year ago
Quoted from chuckwurt:
That’s not what you’re trying to do. You want to see if another switch on the playfield registers when it shouldn’t. That is what is causing the early ball eject. The ball shouldn’t eject until another switch is made. My guess is another switch is registering when it shouldn’t.
Don’t tap the playfield. Pound on it with your fist. Shake the game vigorously. See if you can get a switch to show up in test. Raise the playfield and shake it in your hand.
I gave the playfield a good pounding and I did get a few switches to close. I checked each of them and all seemed to be adjusted with a pretty significant gap and all switch components are cleared of each other.
#6053 1 year ago
We’re you able to reproduce the issue again after that?
#6054 1 year ago
Quoted from La4s:
I would also suspect a possible intermittent diode or short on the switch matrix. Check to see if multiple switches activate when the ball kicks out and activates the shooter lane switch. Also, dooe the game add score before you launch the 2nd ball and before the locked ball activates a switch? This may help narrow down the exact switch being activated if that is the issue.
I see now that the score is increasing each time the locked ball is being ejected early but the score increases by a different amount most every time? Seems to be significant scores of 15k up to 50k??
#6055 1 year ago
Not sure what scores those amounts. But definitely a switch or two somewhere else that is scoring when it shouldn’t.
#6056 1 year ago
I have a Super Orbit (Gottlieb system80a) that I finally got to work!
There are a few issues still that I would need help with. I dont have the manual so it is a pain to understand where I should start.
SWITCHES:
4 Switches are not registering points, and failes in the dignostics menu. But they are testing OK with the dmm (shows continuety when activated).
Among those is the slingshot switch, slangshot fires when hit by the ball, but no points registered.
Same thing with one of the pop bumpers (fires but dont register any points).
POP BUMPER:
The third pop bumber is not working at all (no points and dont fire).
DISPLAY:
Working OK. But when not in play, it shows "0.000.000" for 5 seconds, then "2.000.000" for about 1 second, then back to "0.000.000" and so on. This happens on all 4 displays.
Is that an error code, or a display issue? If display issue, where to start troubleshooting?
OTHER:
Q40 on the driver board test different than all other transistors (diode with a dmm and game off). It is not shorted, but tests about 800 mv both directions, while all other transistors test 800mv on one direction, and 1400mv the other direction.
Not sure if that is normal though. What does Q40 control?
I should add that I have removed all boards from backbox, and the pop bumper driver boards, and reflowed solder, cleaned contacts etc.
Appreciate ANY help here, it's a pain without the manual ;(
#6057 1 year ago
Quoted from ravve:
Quoted from ravve:
So get a manual. Seriously.
Having a manual makes it easier for us to help you.
Quoted from ravve:
POP BUMPER:
Look at the corresponding pop bumper driver board.
Quoted from ravve:
Did you look at the Pinwiki page?
#6058 1 year ago
Quoted from sparky672:
I will, but was hoping for some advise meanwhile..
I did, i took them all out and reflowed solder etc
Yes, but coumdnt find any info about this
See above for replies thx
#6059 1 year ago
Quoted from ravve:
You could swap them around to see if the problem lies with the pop bumper itself or the pop bumper driver board.
Quoted from ravve:
Honestly, that sounds normal. Turn on game and it toggles between zeros and high score to date on all displays. Maybe somebody programmed a high score of 2,000,000 using step 14 of bookkeeping.
#6060 1 year ago
Thank you, I'll try to swap the boards.
How about the switches, what could be the issue when a switch tests ok with a dmm but not working in game? Leads soldered to switch seems ok.
Thx again
#6061 1 year ago
Quoted from ravve:
Bad wiring, loose/dirty MPU connector pins/fingers, or something wrong with a logic chip in the switch matrix on the MPU.
But again, much of this discussion is completely moot if you don't have a manual. You could check the switch matrix chart in the book and see if your bad switches correspond to an entire row or column or if they are randomly distributed. If you're missing an entire row or column, then you can focus efforts on specific wires, connector pins, and logic chips.
I would also recommend getting a logic probe.
#6062 1 year ago
#6063 1 year ago
Screen Shot 2023-04-03 at 4.01.10 PM (resized).pngScreen Shot 2023-04-03 at 4.01.10 PM (resized).png
Then with the manual you can trace these to specific wires, connector pins, and into the logic chips on the MPU schematic.
#6064 1 year ago
Thank you so much for this! SO next step for me is to buy the manual
Oh and I tried swapping the pop driver boards, and the error is now showing up on another pop bumper so YES, it seems that it is one of the pop driver boards causing the issue! I removed the suspected board (again) together with another working one, and measuring with the dmm shows the same results on both (checked all components and traces, including diode testing the chips). That makes me think that I need to reflow all solder on the non-working board, again. Worth a try at least... can´t figure what else could be wrong witht he board.
#6065 1 year ago
Quoted from ravve:
The transistor? Did you test it with your DMM?
#6066 1 year ago
Yep I did. Really strange thing that everything is testing fine. Was hoping to find something. Guess I should order a new board
#6067 1 year ago
Quoted from ravve:
A couple of mine had loose header pins, but that was in the connector and not the board. You checked the nuts/bolts holding the transistor onto the board to make sure they were tight and electrically connected?
For the heck of it, post close up photos of the front and back of your broken driver board.
Quoted from ravve:
Or get a rebuild kit from Big Daddy on eBay.
#6068 1 year ago
Anybody have a PI80 board they'd be willing to sell?
#6069 1 year ago
Yes I verified the bolts/nuts making continuety as they should. Here are pics, but really Ive spent hours comparing to a working board, visually and by the dmm, and cant find anything that differs! The transistor shows slightly less value compared to the working board, like 550 mv instead of 600 mv, but should still be ok i guess.
20230405_142618 (resized).jpg20230405_142618 (resized).jpg20230405_142628 (resized).jpg20230405_142628 (resized).jpg20230405_142640 (resized).jpg20230405_142640 (resized).jpg
#6070 1 year ago
Quoted from ravve:
Yes I verified the bolts/nuts making continuety as they should. Here are pics, but really Ive spent hours comparing to a working board, visually and by the dmm, and cant find anything that differs!...
If every other component on the board is good, then that leaves the two chips.
#6071 1 year ago
Quoted from psd4me:
Should have went all the way and called it a whitewood.
Yes I agree, even if not calling it a white wood, the natural wood looks really pretty. I’d sand the rest off for sure. Great game, love mine.
#6072 1 year ago
Does anybody know who the main software guy was for Gottlieb around 1982? I really dig the code on my Striker and would like to know who's responsible for it.
Ipdb used to credit Allen Edwall for it, but when I reached out to him on Facebook, he said he didn't do that game.
#6073 1 year ago
So an update on the pop bumper driver board issue. I finally fixed it! It was the cap C3 that was bad and needed replacement. Looked good to the eye, but tested bad with the ESR meter.
Next issues to solve are some switches that tests good with the dmm, but dont register in game. One of them is one of the pop bumper switches.
I cleaned them with alcohol but that didnt do the trick
They seem to be adjusted OK... ideas?
#6074 1 year ago
The only thing you can verify with a switch and DMM is continuity, so if the switch isn’t registering in test, it’s a wiring/diode issue most likely.
#6075 1 year ago
Found this on pinwiki, but not sure where to put the jumper wire..?
"Place the game into switch test
Using a short length of wire, short each column drive to each row return, one at a time
A single switch closure should be shown as each connection is made."
#6076 1 year ago
I think I got it, but need to doublecheck before I do something stupid
To test the right pop bumber switch, using the jumper method:
I should remove the A1J6 connector, power on the game and put it in switch test mode, then put a jumper wire on the connector (the male connector on the board) between pins 3 and 12. Is this right??
Screenshot_20230407_221529_Gallery (resized).jpgScreenshot_20230407_221529_Gallery (resized).jpg
#6077 1 year ago
Quoted from ravve:
I should remove the A1J6 connector, power on the game and put it in switch test mode, then put a jumper wire on the connector (the male connector on the board) between pins 3 and 12. Is this right??[quoted image]
Switch 22 is 3 and 11 it looks like. 3 and 12 is switch 23.
#6078 1 year ago
Quoted from ravve:
Looks like SW 22 is between 3 and 12.
Screen Shot 2023-04-07 at 3.30.36 PM (resized).pngScreen Shot 2023-04-07 at 3.30.36 PM (resized).png
#6079 1 year ago
interesting. So where does pin 10 go to?
#6080 1 year ago
Looks like 3 & 10 go to SW 20. Are we looking at the same drawing?
Screen Shot 2023-04-07 at 3.50.17 PM (resized).pngScreen Shot 2023-04-07 at 3.50.17 PM (resized).png
#6081 1 year ago
Looks like SW 20 to me. Are we looking at the same drawing?
Thanks! So I am right by putting the jumper on the board "pins" (i.e. the edge connector pins)?
#6082 1 year ago
Quoted from ravve:
Yes, the jumper would be simulating a single switch closure. Just be careful not to accidentally touch the adjacent edge finger connection.
#6083 1 year ago
Yes. But I’m learning too. Sorry I didn’t see sw 20.
#6084 1 year ago
Thanks a lot! Going to test that tomorrow. Cheers!
#6085 1 year ago
Don't be sorry. It's all good. I just wasn't sure on the tone of what you were asking/saying ... but that's my fault for making the wrong assumption.
Dots are the connection points. If two lines on a schematic cross without a dot, there is no wire connection there.
#6086 1 year ago
Got it. Thank you!
#6087 1 year ago
I'm making some progress on my Bad Girls multiball issue but still stumped. Thanks to all for the advice. I went ahead and did all ground mods in the head (had just been done in lower cab). I also repinned the mpu/driver interconnect harness. Issue still remained. I then systematically disconnected switch strobe wires and return wires from the mpu while trying to duplicate the early multiball ejection issue. The results showed me that the switch return signal that is triggering the early lockout is absolutely coming from switch 45...the switch that is closed when the ball is staged for multiball in the upper left vuk? I have rulled out the ball bouncing on the vuk switch as I have simulated that manually by jumping that stobe and return on and off for a few seconds. After at least 4 seconds is where I could control the ejection with my testing harness...if Ieave that switch return disconnected at mpu the ball will never eject from vuk. If I keep the return connected the whole time the ball may or may not eject early (the issue itself). If I leave it disconnected for several seconds then connected it the ball will eject instantly as mpu must be reading this as a new switch closure. It would seen that sometimes the mpu is reading the ball in the vuk as a new switch closure and sometimes it is understanding the the ball there is an earlier switch closure? I already swapped MPUs with no effect but I did have to swap game roms. Could the roms be causing this issue? I do have new roms comming in a few days. Any help greatly appreciated!!
#6089 1 year ago
NEVER disconnect or connect anything while the machine is powered up.
#6090 1 year ago
Here's some pics of the Counterforce I've been working on for a while. Painted the cabinet in a candy metallic purple, 2pac clear coated the pf, maple rails and a pascal 4-1 to name a few things. Game also had an original goody bag when I bought it with the warranty cards. Just waiting on a new lift bar for the bg. Going to bring it to pinfest for free play.
20230415_183626 (resized).jpg20230415_183626 (resized).jpg20230416_124224 (resized).jpg20230416_124224 (resized).jpg20230416_131230 (resized).jpg20230416_131230 (resized).jpg20230416_131446 (resized).jpg20230416_131446 (resized).jpg20230416_131451 (resized).jpg20230416_131451 (resized).jpg20230416_131517 (resized).jpg20230416_131517 (resized).jpg20230416_131540 (resized).jpg20230416_131540 (resized).jpg20230416_131805 (resized).jpg20230416_131805 (resized).jpg20230416_204407 (resized).jpg20230416_204407 (resized).jpg
#6091 1 year ago
Quoted from ravve:
cant find anything
I believe I see broken solder joints on that pop bumper driver board. Second picture. at connector pins.
#6092 1 year ago
Quoted from REGNE:
They looked fine to me, but it wouldn't hurt to re-flow them.
Screen Shot 2023-04-20 at 11.52.58 AM (resized).pngScreen Shot 2023-04-20 at 11.52.58 AM (resized).png
#6093 1 year ago
Listed some 80B goodness.
Gold Wings Archived
Fully shopped/refurbished - “Some 80B goodness. 1 of the nicest GW's your going to find. Clearcoated N.O.S. pf, N.O.S. plastics, N.O.S. Translight. Rampomatic pink ramp (clear original included). Powdercoated ...”
2023-04-18
Elburn, IL
3,000
Archived after: 10 days
Viewed: 474 times
Status: Didn't sell to Pinsider
Raven Archived
Fully shopped/refurbished - “Selling my Raven pinball. Clearcoated N.O.S. pf, alternate translight (have an N.O.S. original that goes with the game). Powdercoated siderails, Lockbar and legs. Leds in the pf in...”
2023-04-22
Elburn, IL
1,950
Archived after: 54 days
Viewed: 681 times
Status: Not sold
Amazon Hunt II Archived
Fully shopped/refurbished - “Some rare 80B goodness here. These originally were conversion kits for early 80B games. I think they mainly went overseas. This started as an N.O.S. pf assembly (minus apron and sh...”
2023-06-04
Elburn, IL
2,300
Archived after: 37 days
Viewed: 968 times
13
#6094 1 year ago
Here's a couple of pictures of my 80b collection, the only time they've all been together in a line was for one night at UK Pinfest last year. I don't have a lot of space where I live so I rotate them through loans and storage fairly frequently, I was overjoyed to see them all together. Genesis got pulled for the UK league finals and then later on TX was taken for the classics comp so thankfully I got a few pictures while they were all together!
FB_IMG_1682358519698 (resized).jpgFB_IMG_1682358519698 (resized).jpgFB_IMG_1682358528317 (resized).jpgFB_IMG_1682358528317 (resized).jpg
11
#6096 1 year ago
Nice collection of SYS80B.
Here, MAD SCIENTISTS are working hard on a new project for 2023 DMD80B (resized).jpgDMD80B (resized).jpgWhat ? A new GENESIS of display ? er, no, not only but I can reveal more, this is still a secret
Stay tuned, other revelations could leak out before this summer.
#6097 1 year ago
Quoted from noflip95:
Here, MAD SCIENTISTS are working hard on a new project for 2023 [quoted image]What ? A new GENESIS of display ? er, no, not only but I can reveal more, this is still a secret
Hey, may be just in time for me to pull out genesis for a restore, been collecting parts for a while to help out
#6098 1 year ago
System-80B question; I have a few of these that seem very reliable, yet about every 10 time or so I turn them on the displays do not light up, yet game plays perfectly? However, if it does this I simply turn off and back on right away and the displays always come back on, why are they off every once in a while? Thanks
#6099 1 year ago
Quoted from Classics_Master:
It's the fluorescent light, not sure if it's the starter or what.
#6100 1 year ago
Quoted from psd4me:
Not the light, it’s the blue displays. The light always seems to work fine, this happens on nearly every system-80B I’ve ever owned, but not on the alpha-numeric system-3’s?
Toast-Mach1 Mods Shop
Playfield - Plastics
1,650 (OBO)
Towson, MD
$ 1,159.00
$ 1.00
Pinball Alley
$ 12.00
$ 6.00
Twisted Tokens
$ 40.00
$ 1.00
Pinball Alley
$ 8.00
Cobra Amusements
$ 1.00
Pinball Alley
$ 1,159.00
$ 1.00
Pinball Alley
$ 99.00
RGP Models
1,999 (OBO)
Ajax, ON
4,200 (OBO)
Washington Township, NJ
1,400
Sturgeon Bay, WI
$ 1,059.00
This page was printed from https://pinside.com/pinball/forum/topic/home-for-the-gottlieb-sys1-sys-80b-guys-yep-i-guess-it-a-club/page/122 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
