Recently got a Hollywood Heat-- my first pin
Had an issue with slingshots killing the game. Disconnecting the entire coindoor harness after booting is a valid workaround for now (I have no idea why)
Questions:
1. there's a metal bracket in the top left that isn't really connected to anything -- by the top rollovers, sitting above a rubber post. What is this, should it be jiggling around, does it serve any purpose other than fucking up the back decal when I lift the playfield?
2. The manual says the "post at the mouth of the left side outlanes can be position for liberal/conservative play." I have no idea what post it's referring to, or how anything over here could conceivably be adjusted
3. Aesthetically speaking, one of the previous owners replaced all the rubbers, but did so with clear instead of white. He also used a not-flipper rubber on the top flippers, which I immediately remedied. Seeing as I already bought white replacement rubbers, should I go back to stock white or roll with the clear?
Most pressing issue at present:
Solenoid for the right capture hole isn't firing. Tested it and it looked like it was burned out so I replaced it. Was not the issue. Went back and tested the old solenoid and I am a fool because it tested fine. Gound appears to be good-- looks like it connects to A3J4P13 on the other end. How do I... uh... test this connection?
Added over 2 years ago:
Rubbers have been replaced, so ignore that one lol
