We continue with the Snack Bar video. The asphalt, vegetation, buildings, a plane that crosses the sky has been added and three soundtracks have been tested.
Things to improve and test:
1.- That the light bulbs move independently
2.- Modify the buildings so that they can be seen more on the sides
3.- Change the OPEN sign for a neon-like effect
4.- Make the sky clearer so that the perimeter of the mask is better seen.
5.- As for the music, it will probably be the first we will use, and we will reserve the third one for another video.
6.- Try a firework effect in the sky, to make the video more dynamic.
7.- Create the same video with a long duration of about 2 minutes, so that the user can configure if he wants to use it as a background video when the OPEN Snack Bar is triggered, and while the signal is on.
On the other hand, yesterday I was doing tests with the SD card because I had problems with some brands of cards, I think that everything will be solved today, and I will be able to check the triggers of the videos of the first firmware version.
I was also completing the configuration file parameters, I have added some more although they will not be operational in the first firmware version, these are:
1.- License with unique code to upgrade from Basic to Full
2.- Enable/Disable of WIFI for App, Bluetooth and Wireless system for topper or mods with LEDs
3.- Setting the upper margin of the screen to make it easier to use other screens by adjusting the centering of the image
4.- Adjusting the sound level between 0 and 9 for the next firmware version.
PS: If I can, I will include this video and the trigger programming in the first firmware version, but I cannot assure it yet. If it is not possible, it will go in the first update along with other new videos, sound, and some new parameters in the configuration. This is the first of the videos only available for the Full package.
